Modding MY Matrix Orbital GLK12232 Has Copped it - HELP!
Discussion in 'Modding' started by Shak, 2 Aug 2002.
  1. Shak
    Shak What's a Dremel?
    24 Dec 2001
  2. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    I assume you have turned it off and on?
    If all else fails, whipe the mem and new fonts - works for me.
  3. Mat-d-Rat
    Mat-d-Rat Drive it to the edge baby
    30 Aug 2001
    Yep mine did that too - So I did a full reset on in (with jumper on) then wiped and reloaded fonts, then it all worked ok again... IN fact getting a couple of nice screens sorted on on LCDC with it now :)
  4. Morphine
    Morphine weeee!
    23 Feb 2002
    yeah I tried using smartie and LCDrver with it too, they all seriously f00ked it over, just redownload the fonts to it, reset font metric, and reload and iomages to it. then stick with LCDC and never give into temptation, anything but LCDC for our babies is the devil!:D
    oh yes and after resetting all the stuff, slide the contrast bar around in the MOGD, those programs screwed me over there too!
  5. Shak
    24 Dec 2001
  6. Mat-d-Rat
    30 Aug 2001
    Shak, it's the two direcyl in the middle think it's 5/6 whichever way you you look at it (c5/r1 jumper)
  7. Shak
    24 Dec 2001
    Located a Winblows machine and now have just sorted it :) :clap:
    Shak
