Modding My mouse
Discussion in 'Modding' started by corvette, 22 Feb 2004.
  1. corvette
    corvette What's a Dremel?
    27 Nov 2001
    im currently got my mouse to peices with sum bloo LEDs well i found a couple of caps that i can attach the leds to with out a problem and not alot of work will this work or u think it will **** up after a while
  2. PC JUNKY
    PC JUNKY Banned
    7 Jul 2002
    I always thought it to be a VERY bad idea to hook up a L.E.D. directly to a cap :worried: :worried: :worried: unless you are using some sort of resister to limit the power going to the L.E.D.'s.
  3. corvette
    27 Nov 2001
    well ive done it and its been working for the past 6 hours so im happy got a very bright blooo glow coming from my mouse then u turn it over and underneath u have a bright blooo with a dark red centre
  4. PC JUNKY
    PC JUNKY Banned
    7 Jul 2002
    Well glad that worked out for you . . . Will you be posting any pics of it ???
  5. corvette
    27 Nov 2001
    yep just as soon as i get to borrow me mates cam
