Modding My NES PC
Discussion in 'Modding' started by Adolftitler, 18 Jan 2010.
  1. Adolftitler
    Adolftitler What's a Dremel?
    12 Jan 2004
    Hi guys,
    Thought some of you may be interested in seeing my NES PC project.
    Specs are:
    Intel Atom Dual core CPU motherboard
    2gb DDR RAM
    Onboard 5.1 sound and graphics.
    Microsoft wireless desktop with receiver inside the case connected to the USB 2.0 front panel header
    Front USB ports which are NOT wired up, yet
    Micro-PSU and external power block
    Windows 7
    Working on built-in wireless but having a few issues with the cards I have so might need to bite the bullet and mound an internal USB wireless adaptor before I sell it.
    Really proud of the OE look with minimal case cutting (never seen less on any other NES PC build. Hole at side for VGA cable. No additional holes on the console case! Original power button and LED both fully functioning.
    Unfortunately now selling on ebay as my MOT is due at the end of the month :( http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230425427377
  2. Kenny_McCormick
    Kenny_McCormick Minimodder
    19 Sep 2006
    Amen to that, I like it more because it's almost untouched. Great job.
  3. Adolftitler
    12 Jan 2004
    Thanks man, that was my goal from the start. The ones I've seen online have cuts to the top of the case (!!) and even a full back plate on! There's no point making a NES PC if it ends up looking nothing like a NES :)
    I think the difference is I went for a side exit, where as most go though the back, which requires cutting since the NES has an indent where the power connectors are.
    skreenname likes this.
  4. skreenname
    skreenname SFF Forever
    11 Jun 2009
    I love how little you cut into the case.
    That's how a NES casemod Should be done.
    And I love the position of the CD Drive and how clean it looks with the Cartridge cover open.
  5. dohmm
    dohmm What's a Dremel?
    28 Jan 2010
    hey
    I'm in the beginning stages of creating a nes computer and i was wondering if you could post picture or at least describe on how you connected the power switch to the motherboard. also is the motherboard you used an nivada ion with the dual core atom, and can you stream hulu by chance cause im creating this to be a dvr and I've read across some places that the atom 330 isn't the best for playback of hulu.
    Thanks MD
  6. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    i think im in love.
    only thing i would have done differently would be to place the USB ports under the DVD drive under the flap
    so it looked completly untouched
  7. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Looks great! Might consider a blanking plate under the DVD drive to fill that hole?
