Food & Drink My new homemade pizza oven
Discussion in 'General' started by Boscoe, 23 Jan 2011.
  1. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Just made this. I cut an old empty butane tank in half and cut a hole in the bottom for the air then put a couple of peices of metal across the hole and welded then a couple of bricks go on top then fire. I have a mesh panel for the top (you let the fire die to embers) on top of which a thin stone will got for the pizza then the other half of the tank for the top heat which will have a couple of holes in that.
    Will be trying it out soon.
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Nice ghetto mod, but i have some concerns when it come to it's ability to cook a pizza. You will need a bit more heat at the top for the filling to heat up before the bread gets burned.
  3. Boscoe
    5 Jan 2010
    I'll have the top on to heat then quick slide the pizza in.
  4. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    mmmmm pizza
  5. Matticus
    Matticus ...
    23 Feb 2008
    I will follow my nose around Peterborough until I find where you live. I am South-West, I will start at the A1 and work my way up. :hehe:
  6. DeadP1xels
    30 Nov 2009
    well hungry now...
  7. Smilodon
    25 Mar 2003
    I see. Then it may work :)
  8. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    What kind of stone will you be using?
  9. Boscoe
    5 Jan 2010
    Well i've been doing some reasearch into this and because i need a small peice i'm going to have to buy some custom, I think i will be using terra cotta.
  10. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    won't the trapped air in most terra cotta cause it to explode?
    May i suggest casting your own slab in concrete, more chance of not getting something with trapped air bubbles.
  11. Smilodon
    25 Mar 2003
    Why not use slate?
    Shouldn't cost that much, and can be cut to size with an angle grinder or even a coping saw as long as you have the correct disc/blade.
  12. Boscoe
    5 Jan 2010
    Apparently not if you gradually heat it.
    Hmm sounds good I'll have to look into it I'm not 100% sure yet.
  13. omicron
    omicron Baud.
    8 May 2004
    Granite would probably be the ideal choice, but I've no idea how expensive it is these days.
  14. Guest-16
    Guest-16 Guest
    How do you guarantee a butane tank isn't 100% devoid of ANY flammable gas before you take an sharp cutting tool to it?? Even if it has no pressure, surely there's still the risk of explosion since you start showering friction sparks inside...
  15. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    I'm guessing he just warned the bottle that if it flames, it will be permabanned :D
  16. sesterfield
    sesterfield What's a Dremel?
    30 Sep 2008
    fill it with water?
  17. jhanlon303
    7 Sep 2006
    That was my first thought too!
    I'm paranoid after decades of working around car gas tanks and them buggers will surprise you plenty even after years of sitting supposedly empty.
    john
  18. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Looks like 13Kg of fun :D
    He could have punctured the empty can, with something other than a spark producing cutting tool, and flush it out with copious amounts of pressurized air or like sesterfield said fill it with water
  19. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    yeah, maybe tag the thread with don't try this at home kids
  20. Pookeyhead
    30 Jan 2004
    That was my question as well. That struck me as incredibly dangerous.
