Cooling My new RBX what you think??[56k]-Setup and posting
Discussion in 'Hardware' started by M_D_K, 15 Dec 2003.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    and it boots :D
    alll down to the ubber 1337 GFX moddage :D
    :D
  2. Conrad
    Conrad What's a Dremel?
    23 Jul 2003
    yeah but can you squeeze it all in to a case, or is it some kind of new elite desk pc ;) looks good... altho tubes everywhere!!!
  3. Theo
    Theo What's a Dremel?
    12 Jun 2003
    That's not a heatsink from a minifridge, is it?
  4. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    nah its a sink i found in one of my boxes from an old Voodoo i think.
    It had a load of cunk on the bottom so i took it out to the garage charmed up the compresser and removed it all with a sander it now has a shiny base :p
    I then proceded to fix the sink on with a single lug and then orientated so that it would fit then added a Zip tie for good measure as it was not holding down proper, seems to work might find more of a perminant solution or wait for a GFX card to turn up on my door :D
    /thanks monkey spank :thumb:
  5. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    I've never really liked the idea of water cooling a computer. But with all these awesome pictures of setups.. I might end up trying it out myself. :thumb: :dremel:
  6. Wndrbread
    Wndrbread What's a Dremel?
    13 Dec 2003
    That heatsink (the silver one) is from a VooDoo3 3000 ( i have it too : P )
  7. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    yeah
  8. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    mmmmm the daily milk there. Bubbely, they are soo nice
  9. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    And I thought I had too many hoses in my case. It makes it hard enough to get my case door off cause the hoses like to stick to the lexan after awhile. That's gotta be a casefull.
  10. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    MDK where did you get those blue splitter blocks?
    As I need some just like that.
  11. paulus
    paulus WaterCoolingShop.com
    23 Nov 2003
    Looking good!! Whens it going into a case ?
  12. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    MDK i feel your urge to hand over your setup to me, do you know of any other hold-down's that are a bit cheaper, i wanna get one but not the hold-down lol.
    'doc
  13. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    They where from coolercases im sure therewould be a shop in the US that ships em else email coolercases and see if they'll ship to the US
    2 Port manifold
    Thats what your looking for i think :p
    Im in the process of designing and constructing the case at the moment. Put it this way you'll be blown away when you see it[i hope] You couldn't get more custom then the thing this is going in lol :p.
    Hmmm i don't feel that feeling lol :D. Um not sure of any other hold down kits but the ones you get with the blocks. You could make some out of plexi if you where very skilled in the art of craftsmanship but apart from that i dunno.
    Thanks for the comments keep em coming and stay tuned for a monster of an update in the next couple of weeks. project will be put on hold for the next week due to lots of exam and **** going on :(
  14. Guest-16
    Guest-16 Guest
    Mmm creative graphics card. Is it 5ns ram? GF256 DDR?
    Anyhow, looking good :) just needs a case :p
  15. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    TNT2 Ultra :D
    got it off a mate with no heatsink so i had to improvise. Seems to work ok although sits a bit dodgy in the slot lol
  16. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    :worried: all your reservoir are belong to..me :worried:
    :thumb:
