There she is. Hard lined. Not quite done but getting there soon enough. The top It will be covered with a second shroud. This is the main loop. My flowmeter. Its called project hard lined in the project logs thread. What do you think of the loop?
Temps are awsome actualy. 26-27c with fans on 7v @ idle and loading in the 35-37c range. Not bad. Especialy considering my chip. But thats a roughly 9c drop acording to my mobo from my previous setup. Pentium 4 ht (630 series) 3.0ghz @ 4.35ghz and 6600gt @ 610/1240 The flowsensor reports roughly 3L per min. Considering my pump its actualy pretty decent. Im happy what can I say.
Wow, impressive! Nice overclock too. What do you think of my new loop? here (sorry to pimp, but its not seen much action)
Ive got a question tho.....what happent when you need to remove hardware?? As you have solid copper pipes soldered in such a formation what will happen if you decide to change sumthing?
I also used compression copper fittings that would allow me to undo my pipes in sections so I can change things and or upgrade. Or plainly clean them.
