Planning My next Project Ideas
Discussion in 'Modding' started by WolfandAngel, 18 Nov 2010.
  1. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    Well as most of you know I recently finished my latest project Sidewinder and ATM I'm planning my next one. For this I would like to have a lot of input from you guys.
    My plan is to build a very light and small mod.
    Cooling: Air or Water
    Motherboard: ITX
    PSU : SFX12V (small)
    wolfie
  2. WolfandAngel
    2 Dec 2008
    The initial design is going towards a Stealth type plane/boat
    My first attempt at rendering:
    This mod is supposed to be made out of carbon to make it very light and sturdy.
    wolfie
  3. Captain Awesome
    Captain Awesome What's a Dremel?
    19 Nov 2010
    Looks interesting, but how will you open it? A normal door seems hard to manage while keeping the stealth look. And space is also definitily (definetily?) going to be a issue here. I'm lookin forward to seeing more pics/updates
  4. WolfandAngel
    2 Dec 2008
    I'm probably going to make it like a drawer, so that I can pull out the complete rig.
    made it a bit more bumpy and with a little lighting
    not really sure if I should keep the middle post on the air intake:confused:
    wolfie
  5. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    WOW....wicked design....I'd ditch the middle post though ;)
  6. memeroot
    memeroot aged and experianced
    31 Oct 2009
    put it on wheels!
  7. cchr
    cchr Minimodder
    24 Nov 2010
    Actually i think it looks good, imo, i would make the openings a bit more narrow, it looks unnecessary and i think it would cause spatial problems as far as the location of the case.
    Also, i wouldn't want to hit my leg by accident on one of those pointy edges..
    Try putting a black mesh on the fan and see how it looks, it would also protect things from.. well.. hitting the fan :D
  8. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    if it was on wheels it would roll away
  9. Cheapskate
    13 May 2007
    Carbon fiber should be used with organic shapes. :p
    Otherwise, I like it. You should use some of the fan duct space for a hidden USB/esata port.
  10. WolfandAngel
    2 Dec 2008
    thanks
    thanks for your input
    :naughty:
    renders this pic just for you ( Lian Li wheels)
    Kind of looks like a funny car thing.
    I love you, yea your right carbon should be in sheet and wavy parts and not on corners.
    My first try making something roundish with Soap Skin & Bubble
    plugin. For some reson getting weird pointy bits on it:wallbash:
    Wish ther was a kind of brain plug in so that I can transfer my ideas to the PC because what I've got in my mind doesn't look any thing like that:waah:.
    Oh well I already planed on doing a bunch of mock-ups like I did on Sidewinder.
    wolfie
  11. cchr
    cchr Minimodder
    24 Nov 2010
    i prefer the original design with no wheels..
    try adding a narrow "aerodynamic" window on the original and see what happens.
  12. WolfandAngel
    2 Dec 2008
    after a talk with cchr I came up with this:
    A cone/ bullet thing
    and a very ruff sketch of it with fan and feet
    wolfie
  13. cchr
    cchr Minimodder
    24 Nov 2010
    nice, i like it
    a teardrop shaped base would look good on it i think
    cheers,
    chris
  14. james-milligan
    james-milligan Minimodder
    21 Sep 2010
    Wow the most recent pictures look really good! And yes I think ditching the wheels idea will be good ;)
  15. WolfandAngel
    2 Dec 2008
    thanks chis
    :D
    ATM I am moving, remodeling my workshop from the attic to basement, and trying to find sme stuff for photographing. So that I can make more pics of the Sidewinder
    staying with the cone, did a rocket for fun
    wolfie
  16. 0rbibital
    0rbibital What's a Dremel? Stop asking that!!
    28 Feb 2010
    Carbon and rocket don't fit to getter I think .
  17. infekted.one
    infekted.one What's a Dremel?
    7 Nov 2006
    i think you should go back to your original idea stealth, maybe SFF case and hinge the top like and armour case
    may be like that one in james bond oh wait *sec* linkie
    http://tiny.cc/qxnff
    or even
    http://tiny.cc/dzefp
    oh and carbon fibre rox:rock:
    i have a CF fetish!!!!!:blush:
  18. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Hey it looks kinda of like my case Aelro Dynamic! The hardest part about your case is getting crisp edge lines. Doing a multi-faceted design, is very complex, just look at my project log for Aelro. You either have to weld the edges, or create mounting for all the flat pieces, which, can be a pain! You say you want to do it out of CF, I commend you for trying, getting tight crisp edges with CF will have its challenges once again. Stunning design by the way, I will keep my eye on this.
  19. Friend in Science
    Friend in Science How do I science?
    19 Dec 2010
    Ha, looks like a rocket. {insert clever scientific phrase}
  20. coffinator
    coffinator What's a Dremel?
    2 Jan 2011
    like the design. Just a heads up. Part of the stealth design was to not create 90 degree angles. the outboard sides of your inlet seem to be very close to 90 degree angles. You might try adding a flat triangle shape to eliminate it and add a little different shape.
    love this design. reminds me of a high bypass turbo fan. the only problem I see is airflow. The cpu cooler and power supply seem to KILL the airflow.
