Case Mod - In Progress my own project log at last Take 2 - update 28/07/12
Discussion in 'Project Logs' started by bagman, 24 Nov 2010.
  1. bagman
    bagman Minimodder
    18 Apr 2009
    as some of you may know i have wanted to do my own mod for a long time now
    my specs are
    lian li A70
    corsair 550w will be braided
    asus maxiumus III formula
    860 i7
    corsair 2x2gb 1600mhz dominator DDR3
    evga SC 460gtx
    and it is going to be water cooled by a 120.3 rad and a 120.2 rad in a single loop
    anyway because of a few things that have come in the post recently i finally can!!
    that is a tapping screw of 6-32 and a tapping wrench, as my lian li motherboard holes are M3 holes and they need to be 6-32 for standard motherboard stand offs
    here is what i came up with, now the stand offs go in!!
    time to get the jigsaw out and i am too cool for proper eye protection:hip:
    made a nice cut out for my mounting brackets
    but being a true newbie at modding i did not measure how large i needed the hole
    so i got some precision work done
    thats better
    now i need to go and buy a dremel 300 they are on the black Friday sale which is good for me:)
    well thats all folks and thanks for reading my first project log
  2. Teelzebub
    27 Nov 2009
    Glad to see you've got it started mate, You are off to a good start I will have to keep an eye on this one :thumb:
  3. bulldogjeff
    2 Mar 2010
    Ha ha you missed the hole:clap:
    Now I've got that out of the way. It's off to a good start, luckily when you do that it's easy to take a bit out, if it was the other way, putting it back is a right bitch. looking forward to more I'll keep an eye on this one.:thumb:
  4. Teelzebub
    27 Nov 2009
    Now Now Jeff keep it clean lol :nono:
    Apophis54 likes this.
  5. bagman
    bagman Minimodder
    18 Apr 2009
    thanks jeff and bumsrush
    i got something in the post today so i can carry on my project
    so i managed to get the last of the small holes
    but my new dremel disk doesn't seem to like doing many cuts in quick succession :D
    here i am sanding my motherboard tray so that it is ready for painting then i should be able to put some U channel on it
    should be able to get down to painting tomorrow, done a test sample today to see how that turns out, then i should be able to put on my first coat of primer on my board
    thanks for checking out my project log
  6. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Looking good so far man, I'll keep an eye on this!
  7. bulldogjeff
    2 Mar 2010
    looking nice and tidy:thumb:
  8. DeadP1xels
    30 Nov 2009
    Ahhhhh thats cleaner
    Me likey :)
  9. Guest-56605
    Guest-56605 Guest
    Great start and subbed :thumb:
  10. bagman
    bagman Minimodder
    18 Apr 2009
    well i started to prime my motherboard try today
    but it didn't come out so well, as you can see from all the spots
    it think it isn't going so well because it looks like this out side of my house and the primer tin says only spray when it is between 10-32 degrees
    so can you give me any tips on how to paint properly without getting lots of spots everywhere
    just been reading up on the cpc modding masterclass on how to spray paint properly
    thanks
  11. bagman
    bagman Minimodder
    18 Apr 2009
    Bit of a thread revival but got an update.
    Now that I have finished college i got the summer to do what I want, which means I can get back to this project.
    I finished painting the motherboard black and putting U channel around the edges along time ago.
    But today I had to convert my roof panel as it was drilled to fit 120.3 rad with 15mm fan spacing, but my rad has 25mm fan spacing. I am happy with how it came out, you can't tell I did it.
    Tomorrow I will be sanding my rads to give a stainless steel look hopefully. As I can't be bothered to paint them. Also got some fans, tubing and barbs coming in the post, so I can actually put a water cooling build together.
  12. jamsand
    jamsand Minimodder
    21 May 2011
    IT LIVES!!!!....I love the colour of that blue btw
  13. Guest-56605
    Guest-56605 Guest
    Looking good M :)
    That anodised blue is a killer colour :thumb:
    Are you still using the Maxiumus III/i7 860 combo?
  14. bagman
    bagman Minimodder
    18 Apr 2009
    Yep the only thing I have upgraded when I first started this project is the ram from 4gb to 8gb. My i7 is powerful enough for me, with water cooling I am hoping of getting some good overclocks. On my old wc set up it got to 4.4GHz with ease, so I am hoping to get 4.5GHz or 4.6GHz, seems I got lucky and got one of the best i7 860.
    I love the anodized blue as well, just a shame it doesn't go well with the motherboard. But I can get over that. I could if i had time paint the red accents on the board blue.
