Modding My Pc casemod
Discussion in 'Modding' started by rito, 20 Sep 2007.
  1. rito
    rito What's a Dremel?
    19 Sep 2007
  2. Nuffenburger
    Nuffenburger The Burgerman Can
    18 Sep 2007
    nice work , need to tidy up the wiring a bit [=, removal of fingerprints? [= would look grate then, nice work once again [=
  3. rito
    19 Sep 2007
    Crap.
    I tried using epoxy to hold the window in place.
    only now i mess up the window and the sidepanal.
    so now i have to redo the entire side.
  4. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    Try searching for video guides on the mod section. Theres a guide there for making windows that will show you how to hold it in via scotch tape and yes it is strong enough (it shocked me as well) but it does work :)
  5. rito
    19 Sep 2007
    Anyone else care to comment?
  6. mattthegamer463
    26 Nov 2004
    Could you list what all you did to it? PS your photobucket account is inaccessible, you need to set it to public in order for us to see it.
  7. rito
    19 Sep 2007
    Fixed photobucket.
    I want and took a raidmax Diamond 228.
    Cut out a window, gave it a paint job.
    Put that stuff on the wiring.
    I'll most likely add more stuff to it later.
    like stealthing the drive, making a fan bay.
    p.s i was thinking about adding a 5 1/2in floppy drive,
    as a conversation piece.
  8. mod-zoo
    mod-zoo What's a Dremel?
    20 Sep 2007
    That looks ok, but as mentioned you definately need to clean up those wires. 1) For aesthetics, they just don't work 2) If you have intake fans up front(which I hope you do), the wires are a detriment to air-flow, get them out of the way. You're computer will love you for it. :D
  9. rito
    19 Sep 2007
    Yes i know my wires are messey.
    But I figure i'll work on the wire more when i get a Modular psu.
    Cus the one i have now sucks.
  10. mod-zoo
    20 Sep 2007
    Definately modular if you can afford it. However, I did see a tutorial of how to make a modular PSU out of "run of the mill" units if you want to save a few bucks. Modular PSU made at home by Darth Invader, it's a decent guide man. Check it out.
  11. rito
    19 Sep 2007
    yeah i hate my psu. it only has 15 amps on the +12 rail.
    btw does anyone know of a cheap but good psu?
