Just sticking my thoughts in one place so you have have a look at what I'm planning over the next couple of weeks and maybe to give you some ideas too start off with an ATCS 210 Get a window put in the side with a nice etch of the eye of horus Get FAR too many lights. (UV, sound activated lightning rod and roswell) a couple of uv active fans a big enermax psu to run the lights Stealth a dvd & a cdw Paint a SB audigy platinum. Stick in a Soyo Dragon Stick in an XP 1800 rip the heatsinks off an Asus 8200 Ti500 deluxe and put on a chromeorb and some thermaltake hsinks rip the hs off the mobo and stick on another chromeorb make a variable CPU fan speed *** this is the cool bit see below*** cut another hole in the side to put in my lurvely matrix orbital LCD use two of the Matrix orbital GPOs to make a digital rheobus for the two fans... use the rest of the GPOs to run the 800 lights *** here's the cool bit in more detail... The Heatsink I'm getting is the silverado so what will happen is I'll have a 4 way switch that will change the speed of the fan to the equiv of 6v/8v/10v/12v (4 nice little leds to show which setting you have too *** Piccies as soon as I can.... old PC f***ed so I can't upload any more piccies :/
window and etch has already been done by CoolCaseMods, but although I have taken piccies my old PC has blown up (either mofo or cpu) so I can't upload anything. New mofo is currently sitting in sodding bournemouth (read: armpit of england) which is nowhere near me so it'll be friday before I have and OS on my machine :/
I would NOT take off the T5 Deluxe RAM heatsinks .. You would have to epoxy the others on anyways and that's not worth it. If would only replace the GPU cooler with a Crystal Orb but actually the ones provided by ASUS are ok.
Nice to see forward planning! I was going to do some more moding but i'm broke after a prezzi buying frenzi
