My Power Supply caught on fire
Discussion in 'Hardware' started by Dash, 7 Mar 2003.
  1. Dash
    Dash What's a Dremel?
    24 Sep 2002
    I started getting loud sounds from my hard drives(as if they where moving twice the speed as normal). So I unplugged some drives from my comp and it worked fine again.
    I then decided to clean out the comp and redo all the wires just to make sure it was ok and after I re-did everything and turned it on I noticed flames from my power supply and a *poof* of smoke came out follwed by a horrible smell. So I quickly turn it off and waited awhile to see if it worked again. Well it posts but my power surge protecter shuts everything down due to a "Overload" from the comp
    It was a Emerex 431 power supply and my questions were....
    Is this normal or did I buy a cheap used good for nothing power supply :(
    and anyone live or die by a certain power supply since I now have to buy another one
    Thank you for any help or information you can provide
    -Dash
    P.S. Don't know if this is important but in the HardWare Monitor it now shows in RED the power fan speed @ 1541 RPM
    Thank you again
  2. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    do u mean Enermax rather than Emerex? ppl are kind of un decided about enermaxs...some say they are good, whiles others insist they are a POS
  3. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    get a real psu and im sure it wont happen...
  4. Dash
    24 Sep 2002
    Yes sorry about that it was a Enermax that I bought used last august
  5. DeX
    DeX Mube Codder
    22 Jul 2002
    Sure you didn't flick the 110V - 230V switch to the wrong setting?
  6. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    A friends PSU went bang the other day
    Looks like it took out the motherboard too. Not good
  7. Dash
    24 Sep 2002
    no everything was the same but now it looks like the credit card is going to take a hit......
    /me hides from repo man
  8. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Antec True Power, solid as a rock and quiet to
  9. Dash
    24 Sep 2002
    Antec True Power is one.....I just pick one up at store and everything is back to normal
  10. Bursar
    Bursar What's a Dremel?
    6 May 2001
    If you do that, the power supply will go bang very quickly. Basically as soon as you put the power cord in and switch the mains on, the PSU will pop, and probably take half the motherboard with it.
  11. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    you know, in the past i've flicked that switch(was about 7, wanted t osee what it did) and all that happened was the computer didnt turn on, was easily fixed by putting the switch back to it's normal position. does it only kill the thing if you have 230V power and set it for 110V? or was i just really damn lucky?
  12. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    Last time I checked, there was a big fuss about enermax power supplies, because they didn't offer any kind of warranty.
    Most manufacturers will offer some kind of warranty and would replace certain components if it could be shown that they were destroyed as a result of the power supply not doing its job as specified. Not enermax. I remember on of Hypothermia's Killer Gaming Rig competitions being put on hold because the Enermax power supply they were using fried just about everything but the drives.
    Not good.
    I've been using an ENHANCE 430W power supply for just over a year now, and no problems. It is designed for Server/workstation use, and has loads of 12V connectors for multiple drives. Has one of the highest 12V current ratings I have ever seen.
    Not sure where you'd get them from now. I got mine from overclock.co.uk, but they don't seem to sell them anymore.
    8-ball
  13. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Yeah, it'll only go bang if your supply is 240V and you set it to 110V.
  14. JADS
    27 Mar 2001
    My old 230 watt PSU is the toughest PSU I have ever come across, it is still working just fine after 5 years of usage, in that time it has been dropped, taken a massive power surge at uni (that killed a few other comps in the surrounding area), had beer thrown on it by thugs who broke into my room at uni in the first year, has survived torture treatment by operating for weeks on end in hot conditions... tough old thing.
  15. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    what i find funny is that you noticed flames and big poofs of smoke, then you turned it back on :D:D:D
    gimme an OEM PSU anyday please :) i have never heard a complaint about them :)
  16. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    I've gone through FOUR OEM PSU's in the past 2 years - I've gotten only Enermax's to replace them - so far they've been the best I've ever used, regardless of the reports.
    Oh well. :sigh:
  17. Ubermich
    Ubermich He did it!
    21 Jun 2002
    That's how it used to be. Everyone swore by enermax, but over time it seems that either the PSUs are wearing down quickly, or enermax's standards aren't the same and they're getting mixed results.
    Different users will always find different results, but enermax gets quite the range.
    I have a cheap antec PSU and have yet to have a problem with it.
