Modding My QWERTY Controller
Discussion in 'Modding' started by davidbacsik, 2 Jan 2008.
  1. davidbacsik
    davidbacsik What's a Dremel?
    23 Apr 2006
    Inspired by chromedecay, I've done a custom painted QWERTY controller that will work with Ableton Live and should be expandable through software to control some more programs. Enough chatter, here are the pics:
    Main Controls:
    Red are transports and the like.
    Black are controls that affect the music (overdub, stop channel, play selected clip, etc...)
    White are the six uneven channels of clips. QWERTY allows two five channel clips on the top row, one five and one four on the second, and two fours on the bottom.
    http://www.flickr.com/photos/89089461@N00/2156159147/
    Overview:
    Would've liked USB, but you work with what you have. Next time I come across a USB keyboard, I'll either paint it or swap it for my current PS/2 standard keyboard.
    http://www.flickr.com/photos/89089461@N00/2156163223/
    Back:
    (Sweet) Stripe
    http://www.flickr.com/photos/89089461@N00/2156956226/in/photostream/
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    try using image tags.
    otherwise, it looks very nice
  3. davidbacsik
    23 Apr 2006
    Flickr wasn't playing nice with the img tags, but maybe I was doing something wrong?
