Watercooling my radiator choice do or a dont???
Discussion in 'Hardware' started by penryn 2 hertz, 5 Aug 2011.
  1. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Middling, not brilliant but not bad :)
    Those fans are good though, nice lighting too :)
  3. penryn 2 hertz
    10 Jun 2010
    it will be cooling a 1090t @3.6ghz and the northbridge that's all i wont it to do...
  4. Bloody_Pete
    11 Aug 2008
    That 'should' be fine :)
  5. penryn 2 hertz
    10 Jun 2010
    what tubeing is the best 3/8 or 1/2 with this rad...
  6. Bloody_Pete
    11 Aug 2008
    TBH it probably doesn't matter, I prefer the look of 1/2 - 3/4" tubing, so thats why I use it :)
  7. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Either is fine, tubing size really comes down to personal preference nowadays; just make sure you get the same size fittings for everything, and be especially careful if they're compression fittings. I prefer 3/8" 5/8" because it's easier to route than 1/2" 3/4" and not as easily kinked as 3/8" 1/2".
  8. Bloody_Pete
    11 Aug 2008
    Yeh, 1/2-3/4" (urg, inches, we should really be saying 13-19mm) only really works in a big case :)
  9. penryn 2 hertz
    10 Jun 2010
    the rad will be going in a cm690 II at the bottom with the outlets faceing away from the psu outlets faceing the front of the case...
