Electronics My RC tank
Discussion in 'Modding' started by ChriX, 8 May 2006.
  1. ChriX
    ChriX ^
    30 Aug 2001
    Thought I would post some pictures and stuff of my last project, just to see what people thought...
    It's pretty simple really, just a PIC, Bluetooth radio module and a motor driver on board, with a couple of servos to pan and tilt the camera. Wrote a simple command set for it and an app to run on the PC to send it commands. The best thing is the camera on top works as a webcam so I wrote a little Java applet to control it, so you get full control of the tank via the internet, it's great for keeping an eye on things! :D
    All the aluminium bits of the chassis/camera mount were originally the side panel of a Lian Li, good recycling I think. :p
    Pics:
    http://chrix.woaf.net/btank/DSCF1796.JPG
    http://chrix.woaf.net/btank/DSCF1797.JPG
    http://chrix.woaf.net/btank/DSCF1799.JPG
    Video clip
  2. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    thats realy cool.
    got anymore informaton about it?
  3. ChriX
    ChriX ^
    30 Aug 2001
    What do you want to know? :)
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    What's the max height of any obstacle it can climb over? After toying with VEX treads, I distrust plastic treads.
  5. bender386
    5 Jan 2006
    everything lol
    if you could just point me in the right direction for making one of these my self that would be realy nice :)
  6. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I would like to know
    What PIC.
    How did you do the BlueTooth intergration.
    Did you yse java RMI?
    Does the PIC do anyking od image processing or something?
  7. ChriX
    ChriX ^
    30 Aug 2001
    If you look at the video clip, that CDROM drive is about the limit, but I wanted to keep it small so I think that is good enough for the size.
    PIC is a 16F876, which I chose because it has 2 CCP modules to use for the motor speed control.
    Bluetooth is done with a BlueSMiRF from SparkFun (very easy!). http://www.sparkfun.com/commerce/product_info.php?products_id=582
    The PIC is nowhere near powerful enough for image processing, I would have liked to try an ARM of some sort and do some basic obstacle avoidance but I don't have the development tools or anything.
    I don't know what Java RMI is so I guess not. :p It's just a normal applet, pic below of the web interface. GAREV was the official project name, Global Access Remote Exploration Vehicle. :)
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    A laser pointer so you can 'aim' it at people would be fun too.
  9. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    That's really cool :cooldude:
    Thanks for posting it; I like to see other people's projects, many times it gives me ideas for my own.
  10. Stuey
    20 Jan 2005
    LoL, I'm not sure that really counts as it had the magazine to ramp it up a bit. Still, that's a pretty decent climb. To get down though, it kinda flopped. How about implementing some IR sensors? If you don't want to have to program them, check out "BEAM" robotics as that branch features simple visual light sensing capabilities.
  11. Miki01
    Miki01 Bored with Computers :(
    19 Feb 2006
    is that one of those Tamiya gearbox kits I see?
  12. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    yeah, adapt it for some extreme off-roadin'
    I wanna see that thing do an obstacle course.
    (Next stop: DARPA Challenge course)
  13. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    What kind of range do you get on that camera?
    I assume it's wireless.
  14. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Have you ever tryed the lego mindsorms kits?
    There great for prototyping.
  15. ChriX
    ChriX ^
    30 Aug 2001
    Stuey, I did consider adding some infra-red 'cliff' sensors so that it wouldn't be possible to drive it down the stairs or something, and there is a connector on my board for doing so, just never got round to it.
    The range on the camera is sufficient, and of course it's wireless. :) The BlueSMiRF has a range that is much greater than the camera though.
    Never looked at mindstorms, and yes thats a Tamiya gearbox kit, Tamiya tracks and wheels too! :)
  16. magi
    magi What's a Dremel?
    26 May 2005
  17. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    LOLi'm having a kit laying around. i'm planning to strip out the pcb. extend it's seding radius and mod it into a r\c monstertruck car with a wireless moving webcam. it could be cool if it wasn't becuase i'm broke :(
  18. parag0n
    parag0n What's a Dremel?
    15 Mar 2006
    Wow, its wierd seeing this, as i have most of the parts to build the exact some thing in a box in my other room :eek:
    All i'm missing is the webcam and the pan / tilt servos... where did you get your camera from? is it one of the £20 ebay wireless cctv cameras, or something build specifically for PCs?
  19. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    Your project looks like alot of fun! Very cool stuff.
    How did you do video transmission? Do you just have a wireless video camera onboard, or is it going through the bluetooth?
  20. ChriX
    ChriX ^
    30 Aug 2001
    Hi thanks for the compliments. The camera is a cheapo wireless CCTV one yeah, it's the smallest one I could find without paying silly money, and yes the video signal is separate from the control, which then goes into a USB video capture thingy.
