Modding My Second Mod - Ammo Box PC
Discussion in 'Modding' started by Racehorse, 6 Feb 2005.
  1. Racehorse
    Racehorse What's a Dremel?
    28 Jan 2005
    Hi all,
    I'm new on here and thought I'd get opinions on a mod I just finished. I know the ammo box thing has been done before (ZapWizard's is great), but this one is a little different than the others I've seen. The wiring isn't as clean as I'd like, but I'm new to this. It's watercooled, Athlon 64 3500+, Asus A8N-SLI Deluxe, BFG 6800 GT PCI-E, 1 GB Corsair RAM, 36.7 GB WD Raptor OS Drive, 250 GB Storage Drive, Audigy 2 ZS.
    Here's what I started with:
    Here's midway through:
    And here's the finished computer:
  2. Arkuden
    Arkuden mow?
    9 Jul 2004
    very nice and clean looking. Sure to turn some heads i can imagine. Thanks for sharing!
  3. Icecoldbagey
    Icecoldbagey Mountain Dew!!!
    6 Oct 2004
    yeah what he said it looks really clean cut and smooth...nice job mate :thumb:
    9/10
  4. Zero_Distortion
    Zero_Distortion What's a Dremel?
    13 Apr 2003
    Whats the name of thet power cable splitter thingy, can't seam to find those seperately anywhere. I assume thats to power a pump or something on the inside?
  5. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Nice clean job, I like the fan grill.
    Make sure and remove those bullets before you go to any public LANs.
  6. Racehorse
    28 Jan 2005
    Zero_Distortion,
    I think that power cable thing is called a Hermaphrodite :worried: Connector. It came with the Asetek watercooling kit I used.
    ZapWizard,
    The bullets aren't live rounds. They've had all the gunpowder removed and the primers shot out, so they couldn't go off. But you're right, I might get hassled about those at a public LAN.
    Thanks for the comments.
    Racehorse
  7. Death Reaper
    Death Reaper What's a Dremel?
    27 Jul 2004
    Looks nice, though I still prefer stealthed jobs on these types of mods. Making it look as much as possible like the item you were modding really makes it stand out, like Zap Wizards Ammo Case.
    But that's really good, I may have to dwelve in some watercooling before I work anymore on my frist mod...because otherwise I can't stealth it that well with fans..
    Anyone got good resources for watercooling (learning setup and all that jazz?)
    Regards,
  8. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
  9. Gabe
    Gabe What's a Dremel?
    19 Jan 2005
    omg thats freaking leet! i would so show that off everywhere i had the chance good job!!!!!
  10. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    Looking good... Me, likes!!!!!!!!!!!! :thumb:
  11. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Fan-dabby-dosey mate. Great job from start to finish - keep it up. :clap:
  12. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    Hemaphrodite!!! :hehe: , sorry im easily entertained
    Nice case, i really like the way you done it so cleanly. how did u apply the yellow text on top because u painted over the original
  13. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    Well it sure isn't like zap's but it is pretty cool! How long did it take you to make that?
  14. Mattt
    Mattt Minimodder
    12 Nov 2001
    very nice. :thumb: how easy was it to cut that metal? cos it looks pritty thick.
  15. TroubledMind
    TroubledMind What's a Dremel?
    9 Aug 2004
    I really like it especially the detail in which the power and reset buttons look like the back end of bullets, or am I wrong?
  16. CraZy
    CraZy Cöstom úser tætel
    1 Feb 2005
    mm nice! :thumb: :rock:
    how many cal. are the bullets ?
  17. Mr.P
    Mr.P What's a Dremel?
    4 Feb 2005
    Where did you get that box? That mod looks btw awesome...
  18. Racehorse
    28 Jan 2005
    alter_ego,
    I used a paint marker (didn't know they existed before) and a stencil to put the lettering back on.
    smoguzbenjamin,
    It took me about 80 hours total to build it. Luckily, my schedule this semester is a lot lighter so I had some time. :D
    Mattt,
    The metal was a pain in the butt to cut. It's really thick. I went through a lot of cutting wheels on the dremel and ruined several jigsaw blades, too. Cutting the metal is what took most of the time. The fan grill alone took me about 4 hours to cut out.
    TroubledMind,
    Yeah, the power and reset buttons are both the back end of cartridges, as is the DVD eject button. The power button is a shotgun shell and the other two are smaller calibers.
    CraZy,
    The cartridges on the side are .30-06 caliber.
    Mr. P,
    I got the box at an army surplus store. They had all sorts of them. They're actually pretty close to the size of an ATX case to start with.
    Racehorse
  19. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    Hey, nice case, but why didn't you wire the pump strait into your powersupply? Instead of having that gay cord come out, it would like 10X better.
  20. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    hey nice job, I'm a big fan of the Ammo cases :rock: , still gotta finish mine...
