Scratch Build - In Progress ⭐ My second scratch build
Discussion in 'Project Logs' started by Jean R built, 19 Feb 2020.
  1. Canardwc
    Canardwc Gentel-Mod'R
    22 Sep 2011
    I very like your approach of crafting by using old stuff and build from almost nothing !
    As I always say, scraps and useless stuffs are tresors !
    Jean R built and MADPC like this.
  2. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Gpu cooler matches the overall design :dremel::clap:
    Jean R built likes this.
  3. Jean R built
    Jean R built Member
    17 Feb 2020
    The main frame, the handle/cable guide, the remote switch case and the CPU cooler bulge are going to be left brushed aluminium, as for the shells I'll wrap them with black PU leather.
  4. Jean R built
    Jean R built Member
    17 Feb 2020
    Here some pics it's not 100% finished, for that you will have to wait a couple more days
    I have put a banana for reference obviously, this came out as a tight build there is not a lot of room left inside.
    I discovered that the 2 big fans addressable RGB have 3 pins 5v, while my MB has 4 pins 12v I'll put a controller for that somewhere in the next months, it's my fault I bought them with the sleeved cables that were on flash sale, and I should have checked in advance.
    But they are PWM, move a lot of air and are super silent so I'm fine with that.
  5. censored_Prometheus_
    censored_Prometheus_ Member
    26 Mar 2019
    All done by brain, bro...
    ...by brain. :cooldude:
    Dot_Kappa and Jean R built like this.
  6. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    censored_Prometheus_ likes this.
  7. ciaognep
    ciaognep Member
    10 May 2020
    you are so funny:rock::rock::rock:
  8. Cheapskate
    13 May 2007
    I opted for a cartoony low-res avatar. That monkey is doing serious stuff.
    The rig looks fantastic. :D It might need some space underneath for better airflow, but it looks better as it is.
  9. ivory2k19
    ivory2k19 Member
    8 Feb 2019
    Really cool, respect!! :rock:
  10. Jean R built
    Jean R built Member
    17 Feb 2020
    Thanks Cheapskate, I like it too especially with the low stance.
    As for the space underneath, at least for now temps dropped some degrees as the temporary case wasn't the best for airflow.
    For the project I was going to craft all feet, but then I had to buy the inox standoffs I bought through Amazon for the top fan, having them available I used them as the case feet.
    The good thing is that they are sold in different lengths, so if I need them longer I can change them in a minute.
  11. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    Just awesome. So much glorious metalwork. :baby::rock:
  12. Jean R built
    Jean R built Member
    17 Feb 2020
    By the way if anyone is interested, the bare case without the shells and the hardware weight 4.2 Kg or 9.2 Pounds.
  13. Canardwc
    22 Sep 2011
    I didn't realise the small tall of your build because I d'idn't get a scale base, now I know it's quite small, I like it so much better than before!!!!!!!!
  14. Jean R built
    Jean R built Member
    17 Feb 2020
    The sewing phase is done :hip:.
    Now I'm going to finish off the handle and the CPU bulge, as they need some fine tuning with the brushing finish to match the rest, they need to be a bit more matte.
    I'm going to start with the power switch case, and the acrylic wing that's going to cover the power switch cable near the GPU.
    My brother think that the handle doesn't really need another metal scale, I'll buy some nicer screws or some nut covers, for the attachment screws.
    The acrylic windows were already done, so I just have to put them on.
  15. Jean R built
    Jean R built Member
    17 Feb 2020
    Update, I'm going to add some holes on the frontal acrylic panel, because it's closer than I thought to the GPU and it get starved of air.
    After some days I've made the choice of removing the remote cable power switch, it is cool as concept, because in that configuration the case doesn't have any buttons, and you turn it on from the desk, but when you have to move it the switch becomes a big hindrance.
    *edit. When posted from the phone during the afternoon I uploaded the file but the Photo was to big.
  16. Canardwc
    22 Sep 2011
    Look at that !
    https://www.amazon.com/SilverStone-...ze-20&linkId=8acb860e218fadf2d2229bb7b188ad52
  17. Jean R built
    Jean R built Member
    17 Feb 2020
