Development My Son Wants To Be A Programmer.
Discussion in 'Software' started by TheEclipse, 19 Aug 2007.
  1. DougEdey
    5 Jul 2005
    C++ is being integrated into the kernel
    Anyway, it's about programming in general, C++ is the best way to learn good habits like OOP.
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I'd go with C++ if you were going to choose out of C/C++. Simply because of the OOP stuff.
    Also, you can make kernel modules and such out of anything (MS has a project where the kernel is C# code, slow as hell though).
  3. TheEclipse
    TheEclipse What's a Dremel?
    2 Apr 2007
    So anymore more books that you could reccomend
  4. RTT
    RTT #parp
    12 Mar 2001
    That book is written by the two guys who developed the language.
  5. TheEclipse
    2 Apr 2007
    What are the advatages of learning C over C++
  6. RTT
    RTT #parp
    12 Mar 2001
    Depends who you ask ;) C almost naturally leads to C++ - he will progress to C++ in all likelihood. Doug will tell you to jump straight into C++, but I would say you should spend at least a little time with C before going to C++. Just my 2p :)
    Bear in mind that the book I recommended is a reference, not a hand-holding guide on how to learn. I suppose that was a bad recommendation in that respect, but it is worth buying to go along side a tutorial type book (for which I have no recommendations).
  7. TheEclipse
    2 Apr 2007
    Thankyou RTT does anyone have any suggestions.
  8. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    Wow 13 yrs some of you guys started!!
    Anyway..here's my history, Pascal at college, C/C++, Java at uni, as well as some php. Trying to learn a bit of C# now.
    so my tip start with C, then C++, then java.
    C is the best to learn. I don't have any books, because we did Embedded C, and it helps to have practical lessons, with teachers. So am stuck on that point. Best to buy some C books and just dig in.
  9. MiT
    18 May 2005
  10. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    In my school we started (and a currently revising) Visual Basic and i seemed too have picked it up fairly quickly. Its not that tremendously dificult either.
    I would really try somthing you can get a visual output and something worthwhile. More than making a picture of a clown appear and disapear...
    So for that instace i would recomend LUA (http://www.lua.org/) used with garrys mod or something similair. I hope he emjoys what ever he chooses!
  11. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    Hi, I am 15 now and was in a similar predicament 2 years back, so I have a few recommendations which made my life easier.
    What OS does he use? Linux is doubtless the easiest OS to learn to program in, mostly due to the open-sourceness of its apps. I use Gentoo mostly because of the ease in which one can write new programs or modify existing ones. If he was willing to switch, it would make his life a lot easier.
    In terms of the language, I suggest C, because it teaches you excellent program design, is portable between OSes and architectures, and because it is so widely used. Before C, I tried BASIC, python, and ruby, and didn't like them at all, mostly due to how application-specific BASIC is, and the overhead of the python and ruby interpreters. If at a later date he wants to learn C++, he will be well on his way, whereas it is very hard to revert to C from C++ if needed.
    I found "C in easy steps" to be an excellent book, as it covers most of C, but concisely, so it also useful for referance. It is a lot less daunting than other books, while retaining most of the factual info.
    The thing I found most important was to focus on a specific app I wanted to make, I chose writing a pacman clone in C for my ipod. Again, it may not be to taste, but I found ipodlinux easy to code for, but rewarding and informative, and the programs are short enough to understand easily. I suggest that early on he chooses a program to design, as it gives focus to the learning experiance.
  12. TheEclipse
    2 Apr 2007
    Thanks Confused FishCake. He Uses Windows Xp/Vista and is thinking about buying a Mac next year. Would want to program applications for windows though.
    Now he has decided to learn C what books would you reccomend for that particular language.
  13. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I only made my sugestion because all Ive ever used was basic and Visual basic in College and both were very nOOb friendly. I didnt really want to learn how to program, and had no idea about any of it but both were really simple to the extent that even I understood what was going on and could manage them lol
    The idea of goals is also a good one rather than just playing about on them
  14. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    Programming graphical applications in Windows is horrific. I would definitely suggest doing it on a Mac, after learning C/C++ he could go on to learn Cocoa (a framework for OS X) which will allow him to make graphical applications in OS X with ease.
  15. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    I'd say start with some basic Java (no real need to worry about pointers) and once you can do some very basic stuff, move on to C (especially learning pointers and memory allocation/deallocation), from there he can either go back to Java or move on to C++ to learn OO.
    Personally I started with GWBasic (back on DOS 4), and moved on to Visual Basic before going to Uni. While some of the basic concepts helped a bit (such as variables, if then else, arrays, etc) I think starting with another language would have been much better.
  16. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    do NOT start with basic / visual basic. Trust me on that. You're only shooting yourself in the foot when the time comes to learn something new.
    Do yourself a favor and start with C++. I recommend the book by Dissection.
  17. TheEclipse
    2 Apr 2007
    Intresting. He is sure he wants to do either C or C++. I really need some of your reccomendations for books.
  18. RTT
    RTT #parp
    12 Mar 2001
    Look on Amazon & read the reviews.
  19. Rebourne
    Rebourne What's a Dremel?
    26 Jul 2007
    Hmmm... Are you sure you don't want to go the route my dad did and tell me I had to be a chiropractor or he wasn't going to help me through college?
    It's a real cheap way of getting out of paying for your kids college if they have any balls whatsoever.
    /bitterness
    I went BASIC -> Visual BASIC -> C++ and it seemed to go pretty smoothly just coding games and programs I wanted to. Plus my highschool had some great teachers that knew how to code and were willing to help students who wanted to learn.
  20. TheEclipse
    2 Apr 2007
    I was really hoping that somone on here might reccomend a book as you can never tell how good they are on amazon.
