Hi all hardcore modders i'm rashi from Sri Lanka ,just wanted to share idea of my mod and wanted get advice from you guys. My current pc is old one here are the specs Intel Q8200 Asus p5q-e EVGA 460 gtx 480gb HDD CM 430 elite casing Well for my mod i have following ideas 1.To sleeve all the power cables and i/o cables (which most of them are completed) 2.To make a decent lighting setup (white LED) 3.To remove the HDD and CD drive bay and replace it with a single HDD drive bay 4.Make a simple fan controller 5.Make lcd display that can show the remaining render time of 3ds max I mostly use my desktop pc to render my 3d scenes here are some pics of my ideas and some of the things i've done Would like to get all your C&C can you guys see the images?
if people right click and open in new tab it works fine its because ur linking to a web page with the image on not the url of the actual image
i uploaded to another image hosting site ,i think its working now any way what do you guys think? By rashiga at 2012-05-23 By rashiga at 2012-05-23 By rashiga at 2012-05-23 By rashiga at 2012-05-23 By rashiga at 2012-05-23
i need to hide the cables :s still don't have a clear idea what to do :S and also have come up with hdd dock also ,hmmmm
here's some images of my first sleeving job https://www.facebook.com/media/set/?set=a.10150614002064601.395139.751574600&type=3
i'm bit confused after reading the rules @Nexxo can you please explain how i should post the post? Thank you!
hi was busy last few days, any way i completed sleaving all my fan cables,and i'm planning to build a front panel using stainless steal sheets will it be gud idea?
K here are somethings i learned pass few days 1.you can use 550 paracord to sleeve a normal fan. 2.Using allan bolts give kind of a professional look. 3.When spray painting using a hair drier to quick dry each coat can quickly do the painting easily. 4.Spraying paint few layers on the cheep heatshrink you use for sleeving can give you a nice look. 5.100 feet of paracord is not enough to sleeve a PSU. What do you guys say?
Yes, you will need more than 100 feet of paracord. Stainless steel would look very good. Remember that it is very hard to cut, file, and sand.
yea got a big problem there any way here's a little bit of a update Please add a comment sorry for not having a detail description of what i'm doing
since there were not much attention for my mod i just stopped posting here,any way thought of posting some pics,i don't think descriptions would be required. more pics on my FB album https://www.facebook.com/media/set/?set=a.10150614002064601.395139.751574600&type=1
