Case Mod - In Progress My Watercooled Lian-Li SR-2 slow build! (Part 3 - Wrapping & Painting)
Discussion in 'Project Logs' started by coolamasta, 15 Mar 2011.
  1. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Hey all,
    Have just started my slow EVGA SR-2 build, I decided to mod an old case I already had instead of just buying a new one that will take the SR-2 mainly because its cheaper but also a lot more fun as well! Its going to be a slow build as the Xeon CPU's are so damn expensive!!
    The case is Question is a Lian-Li PC-70 which I've had a good 5-6 years, its had various builds inside of it, it was up for sale for a while but now im determined to get this huuuuge SR-2 installed into it with decent water cooling, its going to be my home server which will be used for video crunching and folding@home as im aiming to get the CPU's over clocked to 4.2ghz but will be happy with 4.0ghz if they aren't very over-clocker friendly :D
    Hardware planning to go in so far:
    • EVGA Classified SR-2 Motherboard (GOT)
    • Dual Intel Xeon X5650 CPU's (GOT)
    • 12 GB (6 x 2GB) OCZ 1600mhz DDR-3 RAM (GOT)
    • CoolerMaster Ultimate UCP 900w PSU (GOT)
    • Not decided on GPU(s) yet (Just ATI X300 for now)
    • 2 x 2GB WD & 2 x 500GB WD Raid Edition HDD's (GOT 2)
    • EK Full chipset and VRM waterblock (NEED)
    • Pair of Swiftech Apogee XT CPU water blocks (GOT)
    • EK "spin" reservoir (GOT)
    • Swiftech 18w DDC pump (maybe using 2 x 18w DDC's yet depending on flow) (GOT)
    • 4x120 Phobya rad & hopefully another Phobya 2x120 rad (NEED)
    • 1/2 piping and compression fittings throughout (GOT)
    The Lian-Li PC-70 Case
    SR-2 Board too big to fit in standard form
    All Rivets drilled out and case partly dismantled
    SR-2 bolted to the tray, hmm fair bit of overhang!!
    SR-2 and tray put into position it will have to be installed
    That's it so far, need to buy in some aluminium and make a new rear panel to fix the motherboard tray too then look at getting a 4x120 radiator in the top then see where I can get other radiators fitted :worried:
    Much more to come!...... :thumb:
  2. KidMod-Southpaw
    28 Sep 2010
    Nice start here. I love huge watercooled builds!
  3. bulldogjeff
    2 Mar 2010
    Oh yeah, another mega SR2 build, wicked. You should have a look at Kojak's log and the fun he's had with a similar build.
  4. coolamasta
    26 Apr 2009
    Cheers chaps, Just had a look as Kojak's build Jeff, he done very well on that but bit more extreme than what im going for! Hopefully will turn out nice though :D
  5. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    sub'd. Where'd you get the board from...?
  6. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Interesting choice of PSU though didn't think the UCP 900w was up to the job as the SR-2 board needs 2x 8pin and 3x 6pin though i was able to get mine running with a UCP 1100w and a home made 6pin adaptor but not something i'd want to be running daily especially @ 4.2GHz
  7. coolamasta
    26 Apr 2009
    Yes mate this PSU has got 2 x 8-pin PSU plugs, 4 x 6-pin PCIe and 2 x 8-pin PCIe, it should be fine as I wont be using any powerful GPU's on it being a home server/folding rig. 900w should be plenty :)
    The SR-2 destructions recommend the 2 x 6-pin plugs are in when overclocking which I will certainly do but technically I don't need to plug the 3rd one in which adds voltage to the PCIe lanes although I wont be using multi-GPUs (although I'll prob plug it it anyway haha) :)
    Love your recent SR-2 build by the way, work of art :thumb:
  8. extreme moder
    extreme moder What's a Dremel?
    9 Mar 2011
    I have the impression that this motherboard was a "little bigger" than the motherboard tray... :lol: :D
    This project will be very good!
    Congrats :thumb:
  9. H4B4N0S
    H4B4N0S What's a Dremel?
    5 Mar 2011
    MONSTER!!! I'm lovin' it.
  10. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    Coola ..crack on ..:thumb:
    Over sized Mobo's WILL FIT .. lol
  11. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    WOw, gonna look goood :D!
  12. coolamasta
    26 Apr 2009
    Not a lot more progress on the case unfortunately as im still thinking about what to do, I have an idea now and need to draw it out to scale as I have a mate who might be able to make me a new rear panel for the case on a 'hydro-jet' coooool! :naughty: If that works out then I may try and get him to do a new front as well!
    On the plus side I have sold an arm and a leg (well thats not really a plus lol) but now got a pair of hex-core x5650 Xeon CPU's, 12GB (6 x 2GB) OCZ DDR-3 1600mhz and 2 x Swiftech Apogee XT water blocks, currently all fitted and running on my test bench quite happily! :cooldude:
    After an initial burn-in and stress test the Xeons are now running @ 4.2ghz (2.66ghz standard) on water and im quite surprised how little Vcore I needed to get them stable (1.27v) and any of the 12 cores have yet to go over 60 degrees on just a triple 120 rad, I am planning a quad and dual rad in the case so all looks promising temp wise :D
    Heres a few more teaser pics, plenty more to come :thumb:
  13. bulldogjeff
    2 Mar 2010
    Only the one GPU Rob??lol
  14. coolamasta
    26 Apr 2009
    Haha this rig is purely CPU power mate as its going to be my home server/cruncher/folder, the only GPU will be this ATI X300 just purely to have a display!
    Well that's the plan at the moment mainly due to the fact adding any powerful GPUs will A) sap more power which will force me to upgrade PSU and B) sap CPU time!
    As a test on Windows 7 x64 I let it run a few bigadvs and the P6001 projects are seeing 154,000 PPD!!
    Adding just 1 GTX460 GPU for example will drop the CPU PPD a fair bit so GPU folding along with bidadvs will be debatable so im not going to bother TBH, but never say never lol... :D
  15. Dragonite
    Dragonite Minimodder
    15 Feb 2011
    Nice :D Will be following this one closely :D Have the black version of the same chassis so will be interesting on what you might be coming up with :D
  16. jabski
    jabski What's a Dremel?
    25 Aug 2010
    Looks a very interesting project. Look forward to seeing how it develops.
    Please can you explain the two fan holes in the bottom of the case and how they were used before? Did they not interfere with the motherboard?
  17. coolamasta
    26 Apr 2009
    Thanks all, no mega updates at the moment as I have just been really busy with other things recently but heres a couple of new pics, I've removed the back ready for a new rear panel and fitted my quad radiator grill in the roof.
    I'm planning to mod the front from 2 x 80mm fans to 1 x 120mm next and its not going to be staying silver, im in 3 frames on minds at the moment whether to paint it, powder coat it or wrap it ;) I have ideas brewing so plenty more to come... :D
    bulldogjeff likes this.
  18. bulldogjeff
    2 Mar 2010
    Thats a nice tidy job on the top panel.
  19. coolamasta
    26 Apr 2009
    Cheers mate :thumb: Need to get me a quad rad to fill it now! :lol:
  20. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Nice to see an old school case get modded. Subbed :)
