Graphics My Watercooled QUAD SLI GTX 670 4GB Cards Powered with 2 PSU's **Benchmarks PG10**
Discussion in 'Hardware' started by Guest-44432, 25 Feb 2013.
  1. Guest-44432
    Guest-44432 Guest
    :D
    Will see, may have a buyer for the SC card, and I will look to get another F.T.W card. :)
    It's OK, now that I'm getting used to it. But still prefer Windows 7. :)
    No worries mate! :D Once you keep metro to one side, it ain't too bad. :D
    To be honest Win 8 does feel very smooth. :)
    :p:D
    Really? I bet you wouldn't! :D
    Yeah, I was looking into all those mods, and add on's, to make it run and look like 7. :)
    Yep, Will get a 4th F.T.W card, as someone has just bought the SC card. :)
    FTFY :D
    Thanks :D
  2. Guest-56605
    Guest-56605 Guest
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    I tried Windows 8 yesterday, since if I manage to upgrade today my dad wants to run Windows 8 so I thought I would try it.
    Seems all the issues have been fixed that I had with it, apart from the overclock on the cpu not showing in Windows but that was soon sorted by using a mixture between the Asus Windows software and the bios.
    Did some benches on it, and found I was loosing up to a max of 5000 points on 3D Mark so I will be sticking to Windows 7.
  4. Guest-44432
    Guest-44432 Guest
    I'll check it out - I did use a free one when Win 8 first came out. :)
    Cool - Well I have some great OCing results and Score's from 3DMark 11 Extreme to come!! :D
    Just trying to reach the top of the 600series results! :) (Would be easy with a forth F.T.W that clocked the same as my 3!) :)
  5. Guest-44432
    Guest-44432 Guest
    This is the best I can get, limited by the EVGA SC card. :)
    F.T.W cards overclocked to....
    1372MHz Core - 7800MHz Memory!!
    SC Card overclocked to....
    1320MHz Core - 7700MHz Memory!!
    Overclocks only possible in 3DMark 11. :)
    CPU at 5GHz.
    If I had my old Processor which clocks to 5.4GHz and another F.T.W card, I'm pretty sure, I could be in 12th Place.
  6. Guest-44432
    Guest-44432 Guest
    Heaven 4.0 Extreme settings 8xAA
    F.T.W cards overclocked to;
    1306MHz Core - 7800MHz Memory
    SC Card overclocked to;
    1267MHz Core - 7700MHz Memory
    My Custom made Air tunnel's has given me greater overclocks on the memory - As it helps keep the back plates cool, which cool the VRAM on the back of the cards. :)
    By making a seal between each card, gives maximum airflow, which gives maximum cooling, exhausting all heat out the rear of the case. :)
    The fans I use are - Scythe Kaze Jyuni Slip Stream 120mm Fan 1900 RPM. the air flow from these, are fantastic! :)
  7. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I like the "rustic" look of that wind tunnel.
  8. Guest-44432
    Guest-44432 Guest
    :D It may just catch on! Scratch build out of masking tape and fans anyone? :D
  9. Guest-44432
    Guest-44432 Guest
    My Crysis 3 clip using Quad SLI - 2560x1440 - Maxed out - 8xMSAA - My Custom Ultra Config.
    As I have recorded this Realtime video with Afterburner whilst playing, there is about a 20% performance hit on the FPS.
    I struggled to get over 20FPS average in Tri SLI using 8xMSAA- But QUAD SLI has managed to give 60FPS Average with 8xMSAA! :)
  10. Pete J
    Pete J Employed scum
    28 Sep 2009
    Wha?!?
    You mean quad SLI has 300% scaling compared to tri SLI?
    Hmm. I think that my next major upgrade (in 2+ years' time) will have to be quad SLI!
    Guest-44432 likes this.
  11. MjFrosty
    MjFrosty What's a Dremel?
    3 Aug 2011
    If true that's pretty impressive!! Always seemed to me that quad sli offered little over tri
  12. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Top video. I am in the middle of a build right now which will comprise of 2 MSI gtx 660(non ti but oc) 16gb Black Dragon Ram and 3570k. Will I be able to Max this game for 1920x1080?
    Sent from my Galaxy Nexus using Tapatalk 2
  13. Guest-44432
    Guest-44432 Guest
    Yep, but only in Crysis 3. (Haven't tried Crysis 1, 2)
    BF3 was showing a performance hit with Quad SLI. Also not many games can take advantage of Quad SLI, as my GPU Usage was 50-99% across the board, being more or less the lower end of that scale.
    So we need better optimized drivers for Quad SLI and games to be coded to suit. :)
  14. Guest-44432
    Guest-44432 Guest
    You should be OK with FXAA, but 2GB VRAM at 1080p will not be very future proof, unless your happy with running FXAA, which has less VRAM impact. :)
  15. Somer_Himpson
    22 Jan 2010
    Thanks TG looks an awesome game. Just waiting for my PSU to come back from Be Quiet! In Germany so I can complete the build. (2 modular ports borked!)
  16. Guest-44432
    Guest-44432 Guest
    No worries! :)
    Someone has put a thumbs down on the clip...I'll bet money that it's Gunsmith! ReasonRead here
  17. Psyance
    Psyance What's a Dremel?
    6 Dec 2012
    Jealousy is a cruel mistress!
    Good read as always T_G, great to see what can be done :D
  18. Guest-44432
    Guest-44432 Guest
    Thanks mate! I appreciate the good feedback. ;)
  19. Guest-44432
    Guest-44432 Guest
    If anyone else would like a video of a game with Quad SLI, then speak up! (Depending if I own that game). :D
    I'm here till 11:30 before going around the in-laws for lunch. :)
    But I will get your request(s) done in due course. :)
  20. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    Public youtube clip, the odds on Gunsmith disliking it seem pretty low
