Modding My xbox
Discussion in 'Modding' started by sum41, 3 Jun 2005.
  1. sum41
    sum41 What's a Dremel?
    23 Dec 2003
    Well...This pic is before it got screwed..The silver lettering on jewel was eating away by the glue i used and the paint wont stay on it keeps scracthing off..But it still looks cool by my tv with the top not visible .Its soft modded running unleashx ana it has a 80gb hard drive..[​IMG]
  2. fishthecat
    fishthecat What's a Dremel?
    6 Mar 2002
    skins
    I like the colour scheme, it looks a lot better than the origional.
    Have you thought about using stick on skins instead of paint? Those don't scratch as easily as paint does.
  3. Cipher_UK
    Cipher_UK What's a Dremel?
    12 Mar 2003
  4. -Enforcer-5716M4
    -Enforcer-5716M4 What's a Dremel?
    1 Sep 2004
    That's hot!
  5. jerb111
    jerb111 What's a Dremel?
    25 Oct 2004
    could you PM me with some details on installing that 80 gig drive? :D
  6. robbybertu15
    robbybertu15 <b>needs a job</b>
    28 Feb 2005
    Its easy to do. Just get a program called slayers evox auto-installer. All you do is put in the hard drive with the burnt cd of slayers in and it does it all.It adds a bunch of useful program and formats it for you.
    I would show you a picture of mine but the other xboxes would laugh.
