My Xpose (watercooling etc)
Discussion in 'Project Logs' started by _frank`, 29 Feb 2004.
  1. _frank`
    _frank` What's a Dremel?
    28 Feb 2004
    now i wan't to show my current project to you :baby:
    that was the main case:
    at first i did some small work on my cd-reader and the cd-rw by removing all unimportant parts from its front:
    unfortunately the cd-reader got damaged ;( so i have a gray dvd atm. but i'm working on it
    that i did my control unit:
    it's used to switch my cathodes (blue/uv) an control the fan's speed.
    here's a very old pic from the inside:
    than the idea of the cases name an logo was born. for those who didn't get the intention fof the name (xpose=expose) :lol:
    the part down was or still is for getting some fresh air into the case.
    than came the upper part:
    all in one:
    turn on your lights:
    the front is made of aluminium (2mm). i luckily got the logos lasered in it by a friend who has a company with the needed stuff.
    the aluminium is sanded and got a clear lack surface. makes it shine very nice, you know.
    time to change the cooling system...
    watercooling took over my brain so everything had to be silent.
    the psu got modded an a silent fan
    because i'm a poor german student i had to build nearly every watercooling-part myself.
    i'm using a heattransformer 2 and a hydorl20. cpu is cooled by a self-created cooler by sixtron. very great stuff. (designed for gpu/nb but works great on cpu's)
    gpu-cooler(my first watercooling block) looks ugly but does his job quite good.
    backside of the graka is also cooled. but passive. had no fitting copper at home:
    hdd-cooler also selfmade. very easy but should work fine.
    well, nb has to be cooled too;)
    thought about creating a better cooler than for gpu so this one was built:
    that was the main stuff done right now but i'm working on it.
    what i have to do soon:
    -fitting the heattransformer in the case
    -replacing psu things:
    and some silly work:
    fitting a lcd into a p2:
    will sell it soon, if i get my blue/white lcd import.
    a window should come too but had no idea what it could look like.
    tons of images and texts but tell me your opinion :)
  2. white modder
    white modder What's a Dremel?
    19 Sep 2003
    that hd cooler doesnt look fine to me
    can he transport the cold from the water good?
    sry for my bad english
  3. kestrel
    kestrel What's a Dremel?
    9 Nov 2003
    lookin pretty nice so far. the lit logo on the bezel is very nice. The idea to put an LCD in a pII is kinda funny. keep up the good work
  4. white modder
    19 Sep 2003
    and that part of the hd cooler are they soldered together :confused:
  5. _frank`
    28 Feb 2004
    haven't tested my cooler so far. but i know some ppl that use similar coolers.
    they work realy good. (if you notice a hdd only has 2-5w heatgeneration)
    the hdd's are really NOT silent so I will use some noiseblocker mattings to make it silent
    new pic:
    just added my nb cooler to the system (same temp as cpu :naughty: )
    [edit] yes that's soldered :) very easy and effective
  6. DeViLSpArK
    DeViLSpArK What's a Dremel?
    8 Sep 2003
    looks very nice :clap:
  7. WNxPunk
    WNxPunk What's a Dremel?
    1 Feb 2004
    Nice!! :D Very nice hdd cooler :dremel:
  8. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    i always have more respect for people who custom make all their stuff... great job
  9. Nexxo
    23 Oct 2001
    :clap: For a poor German student you're doing pretty well! Great work. Where did you get those silver PSU leads, by the way? :naughty:
  10. _frank`
    28 Feb 2004
    the leads are originally made for sound-systems :)
    you normally have half of it to connect your stereo-system with your subwoofer etc. kindly got a doubled thing in a local german shop. (conrad.com sells these things too)
  11. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    liek wat uve done keep it up
  12. _frank`
    28 Feb 2004
    will do so :brrr:
  13. Litecore
    Litecore What's a Dremel?
    21 Sep 2003
    dammit! that's one sweet bezel i must say..
    great work on that dude. i envy your skills :]
  14. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    I love the front of the case. Those laser cutouts are amazing :rock:
    I like the HDD cooler also :thumb:
  15. _frank`
    28 Feb 2004
    just saw the connector of the old nb-fan and thought about using it some way.
    remembered some 5mm uv-leds (just bought 3mm @ebay but not received them yet) und soldered an uv-light for the nb-block.
    atm only less effect because there is no uv-fluid in the water yet but soon :)
    (agp-port is uv-active. i like this board...)
  16. n0ll4k
    n0ll4k What's a Dremel?
    1 Jun 2003
    normally i don't like chieftech cases
    but your front is very nice
    good job on the blocks
  17. SJH
    SJH Minimodder
    24 Dec 2003
    I absolutely love the front of the case.
    Those laser cutouts look awesome, especially with their glowing effects.
    Keep up the great work :D
    -Sam
  18. JuiceWorld
    JuiceWorld What's a Dremel?
    27 Jan 2004
    Dude, all I have to say is that just looks dirty! Nice job :clap: :clap: :clap:
  19. _frank`
    28 Feb 2004
    thanks for your opinions :)
    thinking about a dremel action in the top. near the front, there will be the radiator's place. behind it, could be a tribal or sth like that. would place a sanded plexi in. and light it blue or white.
    where can i get easy but good-looking tribals?
    Original Dremel Cut Off Wheels proudly present:
    (2mm depp and 1 mm height. width ca. 2cm)
  20. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    Nice work on the front panel! The flame job is pretty sweet.
