Development Mysql unknown!
Discussion in 'Software' started by Bogomip, 22 Feb 2003.
  1. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    PHP:
        $number == "1";
        while($a_row = mysql_fetch_object($query)) {
            while($number < ($result + 1)) {
                if($a_row->number == $number) {
                        <tr>
                        <td width="4%"><?PHP print $a_row->number ?></td>
                        <td width="24%" bgcolor="#3366CC"><a href="<?PHP print $a_row->website ?>" target="NEW"><?PHP print $a_row->name ?></td>
                        <td width="5%" bgcolor="#6699cc"><?PHP print $a_row->age ?></td>
                        <td width="13%" bgcolor="#3366CC"><a href="mailto:<?PHP print $a_row->email ?>">Email <?PHP print $a_row->name ?></td>
                        <td width="20%" bgcolor="#6699cc"><?PHP print $a_row->location ?></td>
                        <td width="32%" bgcolor="#3366CC"><?PHP print $a_row->interests ?></td>
                        </tr>
                        <?PHP
    $number $number 1;
        print
    "</table>";
    I have been pouring over this for hours now and i cannot see why it wont list everything in my database. In the DB they are numbered starting from 1, but when i run this code, if it works atall it will only print the first entry. Any ideas why it isnt working ?
    thanks, Jaffer
  2. RTT
    RTT #parp
    12 Mar 2001
    that's to do with your $number variable being 1. It needs to be as big as the amount of rows in your table.
    mysql_num_rows($result) will return this for you from your query.
    try
    PHP:
    $number mysql_num_rows($query);
  3. Bogomip
    15 Jun 2002
    but the number neds to start oin one, cause in my table, there is a number column, where all the users are numbered. I then compare the number to the row, then use that row. It needs to start at 1 and increase by 1 everytime.
    unless i have misunderstood what you are saying!
  4. RTT
    RTT #parp
    12 Mar 2001
    personally i'd go with -
    PHP:
    $a_row mysql_fetch_object($query);
    $number1 "1";
    while (
    $number >= $number1) {
    echo (
    <tr>
    <td width=\"4%\">
    $a_row->number</td>
    <td width=\"24%\" bgcolor=\"#3366CC\"><a href=\"
    $a_row->website\" target=\"NEW\">$a_row->name</td>
    <td width=\"5%\" bgcolor=\"#6699cc\">
    $a_row->age</td>
    <td width=\"13%\" bgcolor=\"#3366CC\"><a href=\"mailto:
    $a_row->email\">Email $a_row->name</td>
    <td width=\"20%\" bgcolor=\"#6699cc\">
    $a_row->location</td>
    <td width=\"32%\" bgcolor=\"#3366CC\">
    $a_row->interests</td>
    </tr>
    $number1++;
  5. Bogomip
    15 Jun 2002
    that didnt work either, its being vry funny so i just stole me some code form another one of my database things i made. I have no idea to this time what the heck was going on :)
    thanks for your help though :)
  6. RTT
    RTT #parp
    12 Mar 2001
    I've never used a function to call stuff from a db, was kinda guess work :worried:
    I usually do it the long way and use
    $row = mysql_query($query)
    $something = $row['something'];
    etc
