is it possible to call an mysql_fetch_assoc the same way you would call a multi dem array ex. $foo = mysql_fetch_assoc($sql_foo); $foo['col1']['2']; I have looked through the docs and have found no mention
How do you mean? result1 => ("a", "b", "c") result2 => ("e", "f", "g") you want to get the 2nd result of col 1 (result2.1)? If so, not really. mysql_fetch_assoc gets each result to an assoc array then moves the internal pointer along by one. Two options: 1) Loop round dumping to an array, duplicating data and may be annoying. 2) use mysql_data_seek() to move the internal result pointer. If you mean how is the result output, you get an array which gives the results as so result1 => (1->"a", 'col1'->"a", 2->"b", 'col2'->"b", 3->"c", 'col3'->"c") so you can use $result[1] or $result['col1']
