Scratch Build – In Progress Mysterious aluminum project. The project is completed.
Discussion in 'Project Logs' started by Dmitry, 22 Feb 2016.
  1. Dmitry
    Dmitry What's a Dremel?
    3 Sep 2015
    The project started with a surfing site Bit-tech. I caught the eye of project author Dondan.
      He seemed to me very interesting and I decided to make his own version of a compact gaming PC.
    Another sample from which I repelled.
    Here's what I got.
    My project I called "Mysterious aluminum.
  2. Dmitry
    3 Sep 2015
    Basic materials that have been applied, you see in this picture. Skeletons and scrap buildings.
  3. Dmitry
    3 Sep 2015
    He began to cut the panels and openings under the rear connectors of the motherboard and graphics card.
    Also, the overall size of future housing and overall design were identified.
    I decided to limit the shape of a parallelepiped and use black acrylic plus vinyl film with black textured aluminum.
    Body dimensions get the height of 250 mm, length 350 mm, width 186 mm.
  4. Dmitry
    3 Sep 2015
  5. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Nice work so far!
  6. Dmitry
    3 Sep 2015
    Continue. After painting, I began to prepare components.
    The video card Pflit GTX 660Ti did not want to run an extension cord and had to replace it with a less productive Gigabyte GTX560Ti.
  7. arduum
    arduum Minimodder
    10 Mar 2015
  8. Dmitry
    3 Sep 2015
  9. Cown
    Cown Minimodder
    25 Feb 2012
    Looking good so far :thumb:
  10. Dmitry
    3 Sep 2015
    Most overlooked body painting matt black acrylic paint Montana Black.
  11. Dmitry
    3 Sep 2015
    The radiator for the CPU cooler was taken by Ice Hammer and renovated by a Fan Cooler Master Jet flo 120 red.
    As a result of the tests the processor heated up to 62 degrees Celsius at 100% loading of all cores.
    We used the program OCCT 4.4.1.
  12. Dmitry
    3 Sep 2015
    I continue. Installed LED lighting RGB from the graphics card. The backlight is switched on the rear side.
    The motherboard is in place, packed trains. The layout of the final cable.
  13. Dmitry
    3 Sep 2015
    My exclusive CPU cooler.
  14. Dmitry
    3 Sep 2015
    The metal frame was decorated with black acrylic 3 mm thick.
    On acrylic bonded automotive film with the texture of shredded black aluminum.
    All items were cut on a laser machine.
  15. Dmitry
    3 Sep 2015
    The final photos.
  16. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Came out looking sharp!
  17. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    That looks very nice, top work :)
    I would love to be able to build something like that myself, but I have neither the tools or the talent to be able to do it.
  18. Dmitry
    3 Sep 2015
    Thank you! In fact, everything is very easy. Do not be shy, you have to try. Skill comes with experience.
    I am still very far from being the pillars of modding.
  19. Arboreal
    21 Jan 2011
    Brilliant build! I had to re read the thread as I couldn't believe it wasn't brushed aluminium.
    What are the case dimensions? Also, what are you running in there?
    I really like the graphics card parallel to the motherboard arrangement, it looks compact and well ventilated.
  20. Dmitry
    3 Sep 2015
    Case Dimensions: height 250 mm, length 350 mm, width 186 mm.
    Unfortunately the video card for many years and it would be necessary to make maintenance. Map is heated to 65 degrees Celsius. Processor with a 100 percent load up to 62 degrees. Programme OCCT 4.4.1, the processor without overclocking.
