News Mystery Intel 6-core CPU overclocked to 4GHz
Discussion in 'Article Discussion' started by Sifter3000, 25 Jan 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    That is going to be one hell of an expensive processor!
  3. woodss
    woodss Yes Louis Wu
    19 Jan 2010
    totally epic...
  4. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Just what I've been waiting for :D
  5. scawp
    scawp What's a Dremel?
    8 Sep 2009
    Will it run crysis on high??? (sorry someone had to say it)
  6. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Impressive, very impressive.
  7. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    "but dont worry the benchmarks will run 12 threads soon" not bothered about benchmarks tbh, real life? cant see it being useful for a home setup for a while.
  8. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Question - how was 3-way SLI done on it when gigabyte insist on putting the last PCI-e slot at the bottom so that you cant use a double slot card there? Was it done outside a case?
  9. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    You can get cases that allow for that - my Stacker has enough space and any E-ATX cases would too.
  10. Omnituens
    5 Apr 2006
    my 840 Classic supports E-ATX but can't fit a dual slot card in the lowest slot... beginning to think I bought the wrong case now :/
  11. rjkoneill
    rjkoneill What's a Dremel?
    11 Feb 2008
    oh right - is the nda up then?
    and 4ghz?
    really? that is slightly fail if i am being honest
  12. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Its a 2.4ghz chip, the retail one according the the "propsed" intel road mad is a chip called the X980 thats clocked at 3.33ghz. I should expect 5ghz of goodness from that chip is not more :naughty:
    Andy
  13. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    No, the NDA is still valid, which is why I can't you what speed we've got our later stepping Gulftowns overclocked to...
  14. rjkoneill
    11 Feb 2008
    5ghz will not be hard imo
    the clarkdales can do it so this will do it
    24/7 i am guessing around 4.4/4.5ghz being the top end clock just like the bloomfields
    if the nda is still up, why do people persist in posting results?
    what happens when intel decide not to send out ES chips because of NDA breaches
  15. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Better start saving up.
  16. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    If it wasn't you, it would be another one xD
    Now now, since crysis isn't much cpu, let's save it for the fermentation card (it's all gases)
  17. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    any case that has 8 pci slots will support 3-way SLI (antec 902 does but the bigger brother 1200 does not, TK Armor+ has 10)
  18. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    depends what you do at home! & while the domestic market is large, there are other markets out there that are also profitable for Intel that could use such tech right now.
  19. Omnituens
    5 Apr 2006
    Damn, the 840 only has 7 dispite being huge! Not chuffed about that!
    I sense a mod moment coming up. Where's my hammer?
  20. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    Aw bless, 4GHz....
    Nice board but I prefer ASUS
    Try 180x25 for 4.5GHz for benching, 4.25 for 24/7 stable on good air for a Dream PC beating CPC bench score.
Tags: Add Tags
