Scratch Build – In Progress N+1H²0...Project end/Final shots
Discussion in 'Project Logs' started by bugbear974, 3 Sep 2011.
  1. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Wish I had the time and space to do a build like that, one day maybe but top work on this build, looks awesome bud :thumb:
  2. bugbear974
    bugbear974 What's a Dremel?
    31 Jul 2011
    I still can not understand, I think the words of your TotalGaos LEDs are more numerous than mine. Or simply because my desktop is white ... therefore all the light is reflected (effect I wanted) but the elements are less sensitive to UV requested. :grr:
  3. bugbear974
    31 Jul 2011
    Thank you very much, the time spent on this project is huge I think L3P will not say otherwise. But despite all my efforts I am far from perfect, I said that I could further improve the energy efficiency of the desk. I meet the challenges that I start is not really up to my expectations. I still draws a lot of experience for future project. :D
  4. bugbear974
    31 Jul 2011
    Indeed L3P has 300 LEDs in his desk, I have only 144 less than half.
    But the total length of my office which is only 1m05 I thought it adequate. The second reason I do not get a good result is probably due to the color of my desk that is white. I feel that this color is lacking in everything else. I did do some research to try to best optimize the rendering
  5. bugbear974
    31 Jul 2011
    Yes it takes a long time for this achievement and I do not even have money ... But I wish all the modders to be able to realize their dreams and go beyond their ideas and be able to realize as I'm to do right now. :thumb:
  6. bugbear974
    31 Jul 2011
    Hello everyone, here's a little update on my computer it's almost the end for me. And as promised I finished before the end of December. few facilities for drivers update bios flash and I would be most ready for the latest photos.
    By bugbear974 at 2011-12-28
  7. l3p
    l3p www.^.nl
    1 Nov 2010
    Let's unpack that 600D and make some new pictures :)
  8. bugbear974
    31 Jul 2011
    Is not as anxious, I take as much time as you will take for your last MOD. But soon very soon. :D:naughty:
  9. bugbear974
    31 Jul 2011
    Hello everyone, I am very active today and also a little disappointed given the performance of my computer. A whole morning to update the BIOS of my motherboard CHIPSET and then install windows 7 x64. I have a 60GB SSD on which there is almost no room ... (the system is there really that much space?) I only use two SATA 3 SD and yet I 'I really find it difficult to put everything in order. Here are two pictures that can tell you more. Can you please help me to improve this?
    By bugbear974 at 2011-12-30
    Whit SSD OCZ Agility 3 60GB
  10. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Wait. The OS install uses more than 50 gig? That is weird because I also use a 60 gig SSD for my OS (and some programmes) and my windows folder is only 16 gb. I filled it up with common used programmes but the os is about 20 gig in total (with the users folder added).
  11. bugbear974
    31 Jul 2011
    That's why I try to understand. To install I just select the OCZ 60GB of windows to create a space of 100Mb and arrive on the desktop I install the drivers and some utilities no big programs. And now here is what I have left as a space.:sigh:
  12. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Did you do an upgrade of your windows? (first instal xp/vista and then instal 7). That uses around 30 gigs or so? Its quite weird that you use that much space :S
    ~Bladesingerz
  13. bugbear974
    31 Jul 2011
    No I do not do it, I looked for a similar problem to mine on google without any result I suspect of being the only in this case.
  14. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    You have 24GB of RAM right? Have you adjusted the Page File size? And do you have Hibernation enabled? By Default, when Windows installs, it tries to use the same amount of space for page file as you have RAM, and if you have hibernation enabled, there is a file that is similar in size to the amount of RAM you have as well.
    Try reducing the page file size (or removing it) and disable hibernation if you don't need it, and then do a disk clean up and see how much space you have left after that :thumb:
  15. bugbear974
    31 Jul 2011
    Ok i understand, but where I can adjust the page file size?I turn off hibernate.
  16. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    Follow these steps:
    - Right Click on "My Computer"
    - Select "Properties"
    - Click on "Advanced System Settings"
    - Click on the "Settings" button under the "Performance" section.
    - Go to the "Advanced" tab.
    - Click on the "Change" button under the Virtual Memory section.
    - If "Automatically Manage Page File Size for all drives" box is checked... Un-check it.
    - Highlight the SSD from the list.
    - Select the "Custom Size" option
    - Enter the "Min" and "Max" values for the Page File. (I run 1024 Min - 2048 Max with 12GB of RAM installed).
    - Click the "Set" button.
    - "OK" and "Apply" out of all the menus.
    - Reboot computer.
    - Done. You should now have more than 40GB free.
  17. bugbear974
    31 Jul 2011
    Thanks you so much for this explain. I will try it tomorrow.:thumb:
  18. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I've made a picture in the past of it too:
  19. bugbear974
    31 Jul 2011
    Good morning guys, i return on my computer this morning for update my system, thanks you for your help, stay be alert i return here soon.
  20. bugbear974
    31 Jul 2011
    Thanks you again guys i optimize my SSD now the result:
    Final shot and more next week. Happy new year!
