Motherboards N/A
Discussion in 'Hardware' started by MarkW7, 26 Oct 2010.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    N/A
  2. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Using the lowest-rated Radeon 5xxx-series card would allow you 3 monitors (2 off DVI, 1 off DisplayPort) at a time, so 2 cards would get you 6 monitors. I don't know how the tech's going to improve in the 6xxx series, or whether any of the lower-rated cards have been outfitted with the Eyefinity6 setup (or similar) - may be worth digging around for that info before committing to a motherboard switch?
  3. Big Elf
    23 Apr 2009
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    It needs PCI-E power though.
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    Indeed 1x6pin
  6. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    That new card is £140. I was hoping to get a new motherboard and second low end card for that.
    Getting that card would leave me with 4 monitors, and atm i have an alright for what i need 8800GTX taking slot one.
  7. Big Elf
    23 Apr 2009
    There's the HD4350 that doesn't need a power cable and runs 2 monitors which supports 1920 x 1080.
  8. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Oh, forgot to mention. I run Linux, i don't know how nice drivers work with each other as i've only ever ran Nvidia cards on Linux.
    That looks pretty ideal though, no power and fan less as long as it doesn't get too hot. :)
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    A couple of the Asus P45 board have three PCI-E slots:
    P5Q Deluxe
    P5Q Premium
    P5Q-E
    I'm not sure if you can run them all at the same time though.
  10. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    N/A
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    ^The third slot is physically a 16x but it only has 4x bandwidth, meaning you can put a low-end 16x card in there and not worry about it.
  12. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    N/A
  13. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Something like a low-end 8 or 9 series, 8600-9500 or so should handle the monitors if you can still find them. They should be pretty cheap too.
    I'd also look into a 5450 if it wasn't for a linux rig.
  14. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Having a look, something like a 8400GS should do the job? Can pick one up for £30 new.
  15. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    That one's neutered beyond the level i'm comfortable with but i guess it *should* work. But then 30 quid is a lot to ask for one of those.
  16. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    As i can't find any other boards for sale, i'll let the suggestions run for 24hours then probably opt for the deluxe. :(
  17. Tangster
    23 May 2009
    the new 68xx cards can run 4 monitors by themselves.
  18. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    But they're not Nvidia cards.
    MarkW7 likes this.
  19. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Having a quick Google and seeing those cards coming in at around $200 i don't feel that one would fit within my budget and would restrict a future upgrade.
