Electronics n00b alert - switch question - second question now
Discussion in 'Modding' started by Lord_A, 17 May 2003.
  1. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Hi,
    Please excuse the noobness, but I would like to make sure before I blow something up :hehe:
    I am busy installing a switch in my q-tech PSU, this would be the second one that I am doing, the first worked ok as I had a switch almost identical to Macroman's guide here on bit-tech. Only now I have a slightly different switch, here is a quick paint diagram :
    As you can see it has 4 connectors on it.
    When I got this switch (found it in my box of misc. parts ;)) it had brown wires on connector numbers 2A & 1A and blue wires on connector numbers 2 & 1
    I have connected the brown wires as per diagram but it's not working. I am pretty sure that I need to move the brown wire from connector 1A to connector 2. Is that correct? Also, should I bother connecting the blue wires or is it ok to just use the live wire even though the switch has 4 connectors?
    Thanks.
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    I think the contact pairs are actually 1/1A and 2/2A. Try that.
  3. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Thanks that's what I think aswell, just wanted to make sure.
    I'll give it a go in the morning :)
  4. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Ok I have moved the brown wires to contacts 2/2A and it's worked :D thanks.
    oh PS: Should I bother putting the blue wire on 1/1A aswell or is that not necassary?
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's an extra safety precaution in case the blue wire (instead of the brown) is connected to mains live at the plug by mistake, so won't hurt and might help. :thumb:
  6. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Ok thanks for that dude, I'll connect them up then :geek:
