Modding N00b LED question
Discussion in 'Modding' started by [POE]-LuLu, 2 Aug 2003.
  1. [POE]-LuLu
    [POE]-LuLu New Member
    9 Jan 2003
    I've been reading a bit up on LED's and such, but I still cant decide if this is right. If I use a 5 volt LED, and hook it up directly to my 5 volt (red i believe wire), then I dont need any resistors? Regardless of amps/watts?
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    a resistor is to limit the current therefore u should use one to limit the current you can put the LED in anyway and see what happens though if it gets hot i think you should put in a resistor
  3. sik
    sik Banned
    18 May 2003
    Sure you think 5v is the red wire?
    Hint hint.
  4. DeLorean5000
    DeLorean5000 New Member
    3 May 2003
  5. sik
    sik Banned
    18 May 2003
    Sorry, I'm trying to be funny... Slap me.
  6. malcs
    24 May 2003
    *****slap*****
  7. sik
    sik Banned
    18 May 2003
    Thanks.
    God luck with the LED's aswell, just make sure you don't take me seriosuly/get the wrong LED and wonder why it's not working.
  8. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Are you sure its forward voltage is 5V? I've never seen a true 5V LED (except those with a built in resistor). I know many people have made the mistake of reading the specs incorrectly and reading the reverse voltage as 5V.
    Even if it is a 5V LED, you should really put a low resistance resistor in there as protection just in case the 5V supply momentarily peaks higher than 5V. You won't notice any difference in brightness, so put a 10 ohm resistor in there as some form of insurance.
  9. [POE]-LuLu
    9 Jan 2003
    Im trying to do the light your Molex plugs mod, and I thought it would be cleaner if I used a 5volt LED, that way i dont need a resistor just hanging out there.
  10. malcs
    24 May 2003
    you could just make the connections on the resistor very small, and if its placed right you probably will not notice it
