n00b question on power
Discussion in 'Hardware' started by Shak, 18 Jan 2002.
  1. Shak
    Shak What's a Dremel?
    24 Dec 2001
  2. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    The molex (power) connectors which plug into your components have a yellow 12v, 2 Black Grounds and a red 5v carried on them.
    Y B B R
    [O O O O]
    If viewed from head on.
    You don't have to do anything to get them, they just come as standard. :)
  3. Guest-16
    Guest-16 Guest
    its standard on the PSU. Lots of PC components use the 5v line, so a large Amperage (is that a word?) is usually better :)
    my 420W has a 40amp 5v line and 20 or 25amp 12V i think.
    id have to check the sticky label on the box.
  4. RTT
    RTT #parp
    12 Mar 2001
    aye bindi, 'amperage' is the correct term :)
  5. Shak
    24 Dec 2001
  6. Guest-16
    Guest-16 Guest
    cool - u doing a "Richard Whitely" impression when he does countdown? or u just got a dictionary by u? or u know that??
  7. RTT
    RTT #parp
    12 Mar 2001
    nah, i just enjoy physics ;)
  8. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    "Amperage" is NOT the correct word. The word you're looking for is "Current".
  9. wip3out
    wip3out What's a Dremel?
    8 Jan 2002
    LOL gutted.:D
  10. RTT
    RTT #parp
    12 Mar 2001
    ok i should have said it was the correct word, but in the wrong context :p
  11. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    As an electronic engineer, I've never used "amperage". In fact, I looked in my dictionary, and it is not there. The word is current, and current is the word. Just because what is measured in "Volts" is "Voltage", doesn't mean that what is measured in "Amps" (or more correctly/old fashioned "Amperes") is "Amperage". If that relation held true, we'd have "Secondage" for time, "Metrage" for distance, etc...
    In fact, most of the time there's no relationship at all between the names of a measure and its units. Eg Inductance, measured in "Henries", Conductance, measured in "Siemens", and Resistance, measured in "Ohms".
    Thank you class, the lesson is over...
  12. Tim S
    Tim S OG
    8 Nov 2001
    :rofl: :rofl: :rofl:
  13. RTT
    RTT #parp
    12 Mar 2001
    looked in the oxford dictionary just,
    however, lesson taken and understood ;)
  14. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Oooohhh....your dictionary is bigger than mine!!! (curses cheap dictionary).
    Anyways, it's not used. :p
  15. Guest-16
    Guest-16 Guest
    YES! that's the bloody word i couldnt remember!!! dont you hate that, cant think of the word and it plauges you for ages..
  16. Wolff
    Wolff What's a Dremel?
    20 Jan 2002
    dont you see?
    the 'age' holds true for the most important word to an overclocker:
    0WNAGE!
