PSU N00b question time, Ep: "can't remember"
Discussion in 'Hardware' started by Jeff Hine, 22 Mar 2020.
  1. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Is this agnostic of the make of PSU it's used with?
  2. RedFlames
    23 Apr 2009
    As in will it work with any psu? yes... they're just cable extentions.
    Bloody_Pete likes this.
  3. Vault-Tec
    30 Aug 2015
    Yeah that is what I just got. Well, in carbon. They're just extensions.
  4. GeorgeK
    18 Sep 2010
    It's only if you're buying replacement cables to run directly from your PSU do you need to worry about PSU brand. Extensions use your existing cables into the PSU and then these plug into those. Much easier overall but they do create the most unholy amount of cable clutter - no problem if you've got somewhere to hide it all though :)
  5. Jeff Hine
    8 May 2009
    Thank you -- lock, please.
