Modding n00bs 1st real mod
Discussion in 'Modding' started by Arkuden, 9 Jul 2004.
  1. Arkuden
    Arkuden mow?
    9 Jul 2004
    Ok, i know many of you may flame me for picking this case, but i honestly thought it looked cool, and is very lightweight. There were only 1 or 2 minor things that dissapointed me. 1 was that i couldnt stealth my drives with the front panel closed, but it was no big deal really. The other was just not enough room by the bays.
    That being said here are my specs:
    Antec TruePower 430W PS
    Antec Super Lanboy
    DFI LANPARTY NFII ULTRA B
    AMD XP 3000+ @ 2.1Ghz
    1GB Corsair Value Select 184 Pin DD400 PC-3200 (Dual Channel)
    SAMSUNG 120GB 7200RPM SATA Hard Drive
    XFX Geforce FX 5700LE 256mb
    Creative Labs Audigy 2 Gamer
    Vantec "IceBerq" Coppery All-In-One VGA & Chipset Cooling Kit
    ZALMAN CNPS7000A-Cu Pure Copper CPU Cooler
    Samsung 16X DVD-ROM
    Samsung 52X32X52 CD-RW
    Kingwin Thermal Center
    Now here are my pics. Sorry for them being blurry my camera is a pile and im too poor to care enough. Im waiting for my UV Cold Cathode to come in the mail so the board reacts more. I will also be taking care of the crappy fan cover on the front panel and using UV tracing on the lines of my cards. I would like to add a blow hole but im not sure how, nor am i that good with a dremel. Any suggestions or comments will be appreciated.
    The URL will be under each one in case they dont show properly
    Heres the inside: Notice the HS had to be shaved to fit on the cpu. :?
    http://arkuden.com/comp1.jpg
    Here is the front when the two drives were stealthed. The door wouldnt allow them however.
    http://arkuden.com/image1.jpg
    Here is with the newly modded door. The middle was replaced with very thin blue plastic and hard acrylic behind to keep its shape.
    http://arkuden.com/comp3.jpg
    Here is the computer once it was up and running.
    Like i said, i am not finnished doing things to this case. I plan on doing something with the dumb blue thing covering the fan but im not sure what yet. Also i want to add a blow hole if it can help with cooling at all. The PSU is very hot. The case is burshed aluminum so im not sure if anything special needs to be done to dremel the fan hole for it.
    Hope you like it.
  2. Arkuden
    Arkuden mow?
    9 Jul 2004
  3. thesimo
    thesimo What's a Dremel?
    9 Jul 2004
    whats that big push now green button?
  4. 0013
    0013 What's a Dremel?
    7 Mar 2004
    i recently saw that case in a store... it opens a little drawer ... i hate the (manufacturers)finish on that part... just doesn't fit the case
  5. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
    http://www.bit-tech.net/article/117/
    Excelent article on making a top window. And I agree, dremel isnt the thing to be using when cutting a large piece of metal off like that, I'd use it to smooth off the edges though. But I dont actually HAVE a dremel, so I'd probably use sandpaper :p
    (same principle applies to a blowhole as a window... no, I'm not going mad ;))
  6. Nexxo
    23 Oct 2001
    No I don't, it's a perfectly fine case. And I really like what you did to the top door, to make it blend in with the transparent lower half. Nice work! :thumb:
  7. Arkuden
    Arkuden mow?
    9 Jul 2004
    thanks guys. Yeah the little green box is a push open drawer that you can use for screw storage or what ever floats your boat. Thankfully the green pic is just a cardboard insert so its not permanent. You can replace it with anything you wont.
  8. tomd
    tomd What's a Dremel?
    2 Feb 2003
    Samsung drives rock!!!!
  9. Arkuden
    Arkuden mow?
    9 Jul 2004
    they seem to work amazingly so far. Ive not gotten enough music to burn a cd yet and i dont have anything to back up. But the DVD rom is quiet and efficient
  10. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    I was going to recommend this case to a friend and your pics of the inside have made me want to even more now :D . I like the fact that in the insides are shiney and clean looking and the fan placements are excellent.
    Nice job on the front door by the way, looks like it's been there all the time :clap: .
  11. TMM
    TMM Modder
    12 Jan 2004
    v nice job on the door. It looks like its supposed to be there, i love it!.
    Its a shame the Zalman didn't fit very well, they are great heatsinks.
    mod on! :dremel:
    btw: Antec PSUs run extremely hot. you could place more fans to cool it off, but its just creating more noise imo. If it gets really toasty the fans will speed up anyway.
  12. splinter_cell
    splinter_cell What's a Dremel?
    8 Sep 2003
    excellent mobo i have the kt versin of the lanparty, but i really dont like the front of that case, antec is gettin waaay to tacky with their newer stuff.
  13. Skylined
    Skylined Minimodder
    3 May 2003
    Pics and links aren't working for me. :(
  14. SilentDeath
    SilentDeath What's a Dremel?
    28 Jun 2004
    Nicely done. I saw that case at CompUSA and did a double take. The clear door looks much better! :thumb:
  15. Arkuden
    Arkuden mow?
    9 Jul 2004
    Thanks for the comments!
    Im glad to hear that its norm for antec PSU's to be a little hot so now i know that its not an error of my own. :thumb: I think i will be adding a blow hole to help that heat escape and drop my temps a bit :dremel:
    Does anyone have a good guide to create a blow hole, the case is brushed aluminum so im not sure what i need to be weary of. Also any other ideas to help things around would be more than welcome. :D
  16. Goldfish
    4 Jul 2004
    Well like cutting any material, you should mask off the area to avoid scratches. Blowhole probably easiest done with a holecutter, but remember, cut too little off never too much! That way you have good room to finish the edges and get a nice round hole. Also, make sure you get a fan grill/guard!
    I refer you again to the link I gave earlier, where it outlines making a window in the top panel (same principle, different function). http://www.bit-tech.net/article/117/
  17. Arkuden
    Arkuden mow?
    9 Jul 2004
    cool thanks
  18. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    all case mods have to start somewhere. i know that i started out with a horrible looking beige and blue case and made it in to a pretty cool looking computer (what other people have said). this case has plenty of potential just like any other it will just need a lot of creativity and time. MOD ON! :rock:
  19. Clocked
    Clocked Yar! It be drivin' me nuts...
    11 May 2004
    cool case dude and good work on the mods. I got an antec lanboy thats very similar (my nik nak box is over the expansion ports on the back) love the brushed aluminium case and the layout is pretty good too although i wasn't too chuffed about the door on mine and was toying with the idea of puttin a window in it but wasn't sure wether it would work or not from yours i can plainly see that it does, great work and i think I'll have to go for it, although i have to say that it does look a little too dark for my tastes so i would perhaps add a few led's that light up when the muter is on or the door is shut.
    my only critisism (and who am i to critisize...) is that it does look a little messy on the inside with all the cables all over the place but as long as it works i guess thats all that matters
    keep it up dude
  20. Arkuden
    Arkuden mow?
    9 Jul 2004
    yeah the door looks much better imo than the stock look. I want to put some leds behind it to give it the right light. but im no elecrician so im not sure how to go about it with out frying something important haha
    There is a new thread in the project forums for the work that will be started on it. Plus the winamp led vis. i made for it is in there
    http://forums.bit-tech.net/showthread.php?t=63579
    Thanks for the comments everyone. Pray for me as i start the cutting tomorrow.... poor aluminum case :dremel: :duh: :eeek: :idea: :D
