Modding N64 Security screws to place in a case.
Discussion in 'Modding' started by VirtualJedi, 11 Jun 2004.
  1. VirtualJedi
    VirtualJedi What's a Dremel?
    13 Jan 2004
    Anyone know what type of screw driver those N64 use "Generation 1". :dremel:
  2. Firehed
    15 Feb 2004
    No, but I'm guessing it's some sort of wierd triangular or hex type. Your local radio shack or equivalent would probably have the type of bit you need.
  3. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    :dremel: <-- :naughty:
    edit/ or a lightsaber what ever
    edit/ whoa you have an avatar??? Thought you had to have 85 post :confused:
  4. Prophet
    Prophet Minimodder
    19 May 2003
    There the most anoying things ever, I got a bit off ebay to fit in a changeable driver, Its easy enough :) That or radioshack/hardware store should keep them :)
    Proph.
  5. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Its probably a Torx wrench, same thing they use on Compaqs, nothing you cant buy for a few bucks at your local hardware store.
  6. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    it is a torx.. but if you cant find the right torx bit.. then just get a biro, take out the middle, heat up the tip until its nice and soft, then just push it into the hole, then take it out before it dries,
    let it dry,, and you have a good bit :D
  7. asfd
    asfd What's a Dremel?
    29 Jun 2002
    Strange...
  8. VirtualJedi
    13 Jan 2004
    Yea kinda weird huh...
  9. Rekarp
    7 Mar 2004
    good i wasnt the only one to notice
  10. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    yeah, whats up with that?
    and btw you need 75 posts, not 85 :hehe:
  11. Rekarp
    7 Mar 2004
  12. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    From time to time the mods may see fit to bestow an avatar upon a new user, this is referred to as being "kna'd"./ So I think you have been kna'd
  13. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    The bit is called Gamebit. They come in 3.8mm and 4.5mm. I think the 4.5 is on newer systems and the 3.8 would be another before Gamecube.
    You can get it from Lik Sang
    Or is it a Tri-Wing bit?
  14. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
  15. Rekarp
    7 Mar 2004
    i just used a drill and drilled them...then replaced them with regular screws
  16. Fronzel
    9 Mar 2002
    Security bit is any unusual screw set to deter tampering.
    Torx is a security bit. The difference is in saying you drive a car or you drive a Ford Taurus.
  17. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    i got a set of some "security bits" once.. it had tri ving bits, some wiers pozdrive bit with the wings pushed to the side a bit... (never seen those before) and umbraco, torx and flathead bits with that "knob" in the middle... (a hole in the bit)
    i can't remember where i got it though.. :wallbash:
  18. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
    I just went to the local radio ham show and picked up a set of 32 "security" bits for my normal electric screwdriver and a full set for mobile phones for £20 goes all the way down to T4 torx. and the same guy did me a full set of Nokia unlocking leads for £13. Security - what security.
  19. Fronzel
    9 Mar 2002
    The real bitch is this one that is slightly off-round. It looks like a rivet of some kind, but it is slightly off round that a special tool unscrews. The tool is 75 dollars. And it wears out or sometimes fails to grip and you really need to put some elbow grease into it.
    Or the guys that put a screw .0007 microns long in a hole three meters deep. Thanks!
    Then there are the bits with just one hole that you stick a bit with one post in. And they are nice enough to JB Weld the screw in, so you need a hydraulic press just to loosen the damn thing and then the one post on the screwdriver breaks so you are now stuck with a round bit that you can't grip.
    Because of screws like that, I picked up a Dewalt Master Key
  20. Smilodon
    25 Mar 2003
    :hehe: :hehe:
    i have used that method aswell... works every single time... :) :thumb:
