Scratch Build – Complete Na'ir al Saif
Discussion in 'Project Logs' started by Attila, 3 Feb 2010.
  1. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    ooh carbon. I like that idea!
  2. Lance
    Lance Ender of discussions.
    6 May 2010
    Does having the coolers in such deep channels affect how much cooling they end up with? That would be a mod I would love to give a shot.
  3. The boy 4rm oz
    10 Apr 2008
    O...M...G!!!, I can't believe I missed the start of a new oldnewby mod! Curse you University.
    Looking awesome so far my friend, fabrication is as amazing as always and the design and implementation is astonishing. Keep up the awesome work, congratz on your MOTM nomination and +rep for the awesome work so far.
  4. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Congrats on the nomination!
    Loving this build!
  5. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
  6. FrooP
    FrooP can I eat this?
    24 Oct 2007
    [​IMG][​IMG]
    imho
  7. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Words fail me- your skills with wood and metal are just bonkers... :D
  8. Noswal
    Noswal What's a Dremel?
    3 Jan 2008
    Hey, saw this on the MotM. I also saw your fans. If you weren't going for the turbine look, then they look awesome. But if you were, YOU'RE DOING IT ALL WRONG!!! DX Turbines look like turbines because of the blades, not the cone. Straight blades make turbines, cones do not.
    -Nos
  9. omicron
    omicron Baud.
    8 May 2004
    Did you just tell Oldnewby he was doing it wrong? :nono:
    Out! Now! Go!
  10. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    In modding, there is no right or wrong. :thumb:
  11. stonedsurd
    11 Mar 2009
    I think it's just called a turbine mod (putting the cone on the fan hub). It's not really supposed to look like a real turbine.
  12. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Why should we care what a turbine looks like, if we can build our own fans that look this awesome?
  13. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks for the comments. :thumb:
    And nice to see you here B4oz. ;)
    Regarding the "turbines". I merely wanted to make a "kinda like", "evocative of",
    "similarish looking". Get the picture? Maybe I did use the the wrong word to describe
    the look the I was after, maybe they look like giraffes. I just wanted to make some
    chunky and interesting fans that you can't go out and buy. When their spinning they will
    be indistinguishable from a turbine as you won't be able to see the shape of the blades. ;)
  14. Cheapskate
    13 May 2007
    :worried: Unless you try use a jig saw on something in your lap or something.
  15. omicron
    omicron Baud.
    8 May 2004
    Surely that's just inspired modding?
    Look down at your crotch and think: 'Hmm...I could mod that...' :dremel:
  16. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    they make a blue pill for that
  17. Anakha
    Anakha Minimodder
    6 Sep 2002
    I'm not touching that, in any sense of the phrase.
  18. voigts
    voigts What's a Dremel?
    26 Apr 2006
    You know you are waaaaaaaayy too obsessed with modding when stuff like this starts going through your head... :eyebrow:
  19. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    There is not such thing... *looks at the many scars and mutilated fingers which I thought would look better with a exacto blade sticking out of them...*
  20. Attila
    22 Feb 2008
    Hahaha, I shouldn't touch this but..........................................................................
    No, I'm just not going to. :hehe::lol:
    If you remember, I've been working on the various ducting to stuff all the cables into.
    So enough time was available (in small bits here and there) to complete the inside or
    back or underneath, I don't really know what to call it, but it is the part that won't be seen
    and will be covered up.
    So first a section needs to be removed from the large rear channel so that the 24 pin, SATA
    connectors and case fan connectors can bend down into and then sit in the channel.
    Like so.
    Then a lower or rear cover needs to be made for this area from some 20mm "U channel".
    I probably could have routed the part but this was quicker than setting up the router.
    Then drilled, tapped and screwed to the main channel.
    Then all the pieces were bolted together........
    And put back into the chassis.
    It's not a very pretty stage of the build but necessary and will reap dividends
    later on when the covers are made. Hopefully, the motherboard and other parts
    will be visible but nearly all cables and connectors will not. :D
    Back soon. :)
