So much detail, just awesome mate! This thread feeds my hungry curiosity of whats next all the time! Mod on man!
I cant wait to see if you have some ingenious plan for hiding the GFX power cables, they always seem to be the ones that ruin an otherwise clean build
The Mod Brothers had a great Podcast interview with oldnewby He shares his background and projects, and of course Na'ir al Saif! I've posted it here to download and discuss
Very interesting interview! Great idea on the cable channels. This is what I love about an oldnewby project: the details!
cannot believe I have only just found this project, its incredible. Great work looking forward to see it finished.
Thanks a lot everyone. The Mod bros podcast was lots of fun too. Earlier on someone asked whether the fan bodies would be fixed. Well it's time to take care of that before the covers can be made. The fan bodies sit nice and snug in the cutouts and only need a couple of mounting blocks to hold them there. For that reason and because no great loads or stresses are involved, the blocks will be made from plex. First the fan carrier is removed. Then some blocks are cut from 20mm stock. I need some of these for other reasons so more than the four for the mounts are cut using the drop saw. Then for the fan mounts, an L shaped part is cut and filed. After the basic curve is filed to match the shape of the fan body, some abrasive paper is stuck to the body with double sided tape and the final shape made. 4mm holes with 7mm recesses are drilled. And the finished part after trimming down. And after drilling and tapping a blind hole in the fan carrier and the same for the fan body (except I drilled straight through the outer skin here), the first mount is fitted. I'll go away and make the other three now. When the cover goes on, none of these will be visible. Back soon.
The details in your build always amaze me oldnewby. I'm sure we have a new winner on our hands.. I would say congrats on the nomination, but im sure everyone expected as much. great work
It seems pretty late to join in the merriment but i subbed anyway because this case is going to be amazing to say the least.
