Scratch Build – Complete Na'ir al Saif
Discussion in 'Project Logs' started by Attila, 3 Feb 2010.
  1. General_Confusion
    General_Confusion Now Where was I?
    3 Jul 2010
    Awsome work man, can't wait to see it with the hardware installed :)
  2. Cheapskate
    13 May 2007
    OOOH, that's just flippen awesome.:D The way you sunk the screws flush with the surface looks beautiful too.
  3. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Another morning and I see this! LMAO in tears...Thanks:thumb:
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Yeah thats an idea I've thought about but now actually seen it done which confirms it's a great idea, requires thickish aluminium or whatever material though & an ok functioning drill press, I'd need a better 1 than my current.
    Awesome to hear the cover can slide on & not budge only requiring 2 screws, really awesome craftsmanship :rock::thumb: +rep :D.
  5. Attila
    Attila still thinking....
    22 Feb 2008
    scgt1
    talladega
    perplekks45
    B4oz
    LooseNeutral
    shah
    jegerjon
    Fabou
    riekmaharg2
    =WBG=cpt_custard
    AnG3L
    Throbbi
    snakerine
    stonedsurd
    General_Confusion
    Cheapskate
    Waynio
    Wow thanks for the response, and the laughs as well :lol::hehe:
    I drilled some holes and fixed the panel to the chassis today. Because this all worked
    out well I can now finish the fans (sand some more, fill some more and paint) sand
    and polish the plex, re-polish the alu (and find some proper sealer) assemble the lot
    and install the hardware. So completion is getting close. :clap:
    I still have to make a decision on the back (was originally going to have a door here, but
    this would just look awkward as it would overhang the struts and feet too much) so I'm
    thinking about a snap-in panel here. The wiring, although all hidden, will be a lot of work
    because of the available space. Connectors for 24 pin, 8 pin and the two 6 pin GFX leads
    will be removed to save room, and the wires connected directly to there positions on the
    motherboard and graphics card.
    Next time I'll show you the completed fans. :)
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    You're welcome. :D
  7. Donnie_G
    Donnie_G uber learner
    21 Sep 2010
    no updates :(
  8. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    I can really do with a CNC
  9. Attila
    22 Feb 2008
    Yes, I was going to make an update when the fans were finished but the painting
    of the fan bodies is not going well at all. Trying to get a nice finish to the inside is
    very difficult and I've had to re-sand several times because of runs and the like.
    But other things are going well. I've polished the pads and they look terrific, and the
    plexi polishing is proving to be surprisingly easy. Here's some pics. :)
    Hopefully I can get the fans done this week, then things will move along much faster. I can't really do much until the fans are in place.
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Those case feet turned out sweet, very nice work on polishing the plexi, not tried polishing plexi yet & you say it was easy which is nice to know :).
  11. bulldogjeff
    2 Mar 2010
    this thing should be in an art gallery not stuck onthe pages of a modding forum
  12. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    Oh come on!!!!!
    I wants me some shiny alu feet for my case..... If I remember correctly; you posted a tutorial (or guide) on how you polish alu somewhere... right? I may have to go back and check your threads... I definitely wants me some shiny alu like that...
    :clap:
  13. LooseNeutral
    13 May 2010
    MOTY!!!!!!! just for babies new shoes alone. Do they use those plex pieces for money on your home world? LOL sorry, I got an email that said "no update :(". AND I SEE THIS! You really do set the bar high my friend.
  14. scgt1
    scgt1 Minimodder
    11 Jul 2010
    Yea he posted it in this log several pages back. I would find it for you and post the post ID, but I'm sure you've already found it by now. LOL
  15. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    :jawdrop::jawdrop::jawdrop: - enough said. :D
  16. rakesh_sharma23
    rakesh_sharma23 Minimodder
    2 Sep 2007
    This is a super build.
    I like the polish work.
    Can you share how you polished acrylic ?
    Great Build.
  17. Jipa
    5 Feb 2004
    It all looks render-perfect. Can't believe someone can actually get such a perfect finish on all the pieces...
  18. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    What can I say? Are there any more words left????????????? :) :)
  19. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    A excellent quality and very innovative build looking forward to the final product :thumb:
    Thanks
  20. Tangster
    23 May 2009
    Stunning polish skills, but then I never expected less than perfect.
