Scratch Build – Complete Na'ir al Saif
Discussion in 'Project Logs' started by Attila, 3 Feb 2010.
  1. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Wow some fantastic craftsmanship there.
    This is shaping up to be an awesome build.
  2. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Have to chime in again, and I think Jipa nailed what I see.... I like to hang out on the render forum and by the gods of 3D... He's right!
  3. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Skillzz...
    He haz it :)
  4. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    I too would like to know, it looks amazing, and so do thoughs case feet :jawdrop:
  5. The boy 4rm oz
    10 Apr 2008
    Those pads look fantastic all polished up, as does the plexi, very nicely done.
  6. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    I'm your no.1 fan....no pun intended.
    Most guys strive to raise the bar a little for the rest of us. Oldnewby, you snatched the bar away, broke it in two, and now you're beating us with it....
    Excellent work mate. Nothing less than perfection!!:thumb:
  7. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    LOL, you said that very funny.
    But yeah he don't need to hear it anymore, does he? Excellent work mate!:D:D
  8. General_Confusion
    General_Confusion Now Where was I?
    3 Jul 2010
    +1 :thumb:
  9. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    I am speechless, this is really cool your case.
    Congratulations!
  10. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks guys. :thumb: Yes there is a polishing tute back somewhere in the log. To get a good
    finish on the plex, after all the shaping and filing is done, I sand with 800 grit wet using a
    foam sanding block and then using only the loose leaf rag buff and the white compound,
    give it a polish till it's transparent. This happens very quickly and then buff with a soft rag.
    The pieces are pretty good but they are far from perfect. Let me waffle for a bit...........
    Lets look at the case feet., these were turned for me by a friend at work. I gave him some
    drawings with measurements and also the stock. He did a very good job but in fact the
    small diameter of each piece is slightly different. There is a difference of just over 1.00mm
    between the smallest and the largest, all the rest fit in between. But this is OK because the
    struts, which I made by hand, are also slightly different. So, the feet are indivdually matched
    to a similar sized strut. The finish on the feet turned out to be quite good but the finish on
    the struts is not as good, despit having gone through the polishing process twice.
    Then there is the photography., You have to thank the invention of digital photography. I can
    shoot off up to 50 images of a part from every angle, with flash, without, in direct sun,
    in shade, indoors whatever. I pick the most favourable photo's, that is the ones that show
    whatever I want to show, in the best possible way, and load them into photoshop. Here
    auto levels are applied, auto contrast, auto colour, and sharpness. Then the photo's are
    reduced in size to 800pixels on the longest side, this compression has the effect of removing
    a lot of information hence making the photo's look even better. I'm not saying all this doesn't
    look good in real life, I think it does, but it's just not 'perfect', parts can always be improved
    but somewhere I end up drawing a line and thinking 'that's good enough'.
    Thanks a lot guys. :thumb:
    Well today was a beautiful spring day so I tried once more to finish the fan bodies.
    They didn't turn out as I had hoped but I've spent about two weeks on these and I've
    had enough. They look OK but just don't have that deep finish I was after.
  11. rak500
    rak500 Minimodder
    22 Aug 2009
    Unbelievable! This case is fantastic, it's just too good... I can't look at my pc anymore because of this.
    Not only you will get MOTM, MOTY, and featured in MDPC, I think there's a chance the "mod of the decade" will be created because of this. We should probably create a "Modder of the decade" award too, you'll definitely get that as well.
    Very niiiice!
    Those fans are nice, lovely finish!
  12. stonedsurd
    11 Mar 2009
    Gorgeous fans :D
    Love what you're doing so far mate. The polished plexi was fantastic (dare I say, more so than the polished alu?)
  13. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    Very cool.....ALL of it :thumb:
  14. Razer2007
    18 Jul 2010
    outstanding. those look like the kinda fans the president wouldn't buy cuz it's too expensive!
  15. The boy 4rm oz
    10 Apr 2008
    The fans are outstanding.
  16. Nealieboyee
    14 Aug 2009
    Haha... *Looks at own pc and looks away in disgust - UNWORTHY!!! IMPURE!!!* Don't worry mate, we all feel this way after one of oldnewby's updates. Thats why he leaves a couple weeks in between updates - so we may appreciate our pc's once again.
  17. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    I call hax on this one ! :D
  18. Dahl1n
    Dahl1n What's a Dremel?
    16 Jan 2010
    The king of modding :D
    Dont have to say anything more,
  19. Dahl1n
    16 Jan 2010
    The king of modding:rock:,
    i dont need to say anything more right? ;)
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    The fans "they look ok" :) I think you are your own biggest critic m8 :hehe:, to me & everyone else they really do look beyond perfect, I know you said the compression of the pics hides details but still I bet you have to get real close to see any faults & bet most wouldn't see them :thumb:.
