Storage naked 2.5 in-place of 1.8?
Discussion in 'Hardware' started by lxrysprtmscl, 5 Feb 2010.
  1. lxrysprtmscl
    lxrysprtmscl Minimodder
    8 Sep 2008
    as the title suggests...
    would a 2.5in SSD without an enclosure fit in the space of a 1.8in SSD in an enclosure?
    trying to figure out if i can get a better performance SSD cheaper to fit in my Vaio P.
    thanks.
    lxrysprtmscl.
  2. wyx087
    15 Aug 2007
    i don't think so, there's a reason RunCore SSD's are so popular in netbook community.
    but im interested if you can make it fit somehow.
  3. Baz
    Baz I work for Corsair
    13 Jan 2005
    Nope it wont. The PCB isnide is pretty much 2.5" across, so there's no chance of it fitting in a 1.8" enclosure.
    Intel do sell 1.8" SSDs though - the X18 series I believe.
  4. lxrysprtmscl
    8 Sep 2008
    yep. i know. was just hoping for another solution.
    dang. i figured as much. but thought i would ask.
    though i am not exactly trying to fit a 2.5in pcb within a 1.8in enclosure.
    just wanted to fit a 2.5in pcb within the space of a 1.8in enclosure.
    yep. i knew that. hence the naming.
    was just hoping for a better performance ssd for cheaper.
    thanks.
    lxrysprtmscl.
  5. wyx087
    15 Aug 2007
    i know how you feel, the 4000 odd RPM drive in my Compaq Mini 700 is way too slow for anything, i wish i can put my desktop's current Samsung 64GB in it and perhaps buy a good SSD for my desktop, with TRIIM support.
