Graphics naked 4890?
Discussion in 'Hardware' started by infekted.one, 3 Feb 2011.
  1. infekted.one
    infekted.one What's a Dremel?
    7 Nov 2006
    Hi a real quickie here, trying to set up a mates pc he aint got a gpu yet and all i have spare is a naked 4890, i do have a zalman heatpipe cooler that fits but its fan dont work it should be ok for just internet use, right?
  2. bulldogjeff
    2 Mar 2010
    My guess is, it'll fry! Neither card or the cooler are designed to passively cooled.
  3. keir
    keir S p i t F i r e
    5 Oct 2003
    surly you can change the fan if not sit a 120mm fan on it.
  4. infekted.one
    7 Nov 2006
    Im trying to get one on now not a lot to fix it to :( grr
    ramdacs should be fine thou surely
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Underclock it as far as you can and direct some airflow that way?
    infekted.one likes this.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What cooler and case is it?
  7. bulldogjeff
    2 Mar 2010
    A couple of zip ties to hold the fam on willbe enough if it's only a temp solution. as long as theres a decent air flow across the heat sink it should all be fine.
  8. infekted.one
    7 Nov 2006
    NZXT Vulcan matx case with a zalman vf1000 gpu cooler
    I have got 2 80mm fans one mounted to the cooler one blowing cold air on it and damn!!! there noisy forgot how noisy 80mm fans can be, bring back the vuvuzela's
