Modding Named it Plexeon
Discussion in 'Modding' started by coorz, 15 Dec 2003.
  1. coorz
    coorz Miffed
    25 Apr 2003
    Hi guys,
    Couldn't think of a better name so i named it Plexeon, for apparent reasons!
    System specs:
    Mobo: Gigabyte SINXP
    CPU: P4@2.66Ghz
    VGA: Radeon 9700 non-PRO :eyebrow:
    Memory: OCZ Dual Channel PC3500
    HDD: 2x160GB Samsung's striped
    Started with a stock Beantech Acrylic case that needed some lightning scheme. Cuz i wanted something original i opted for....Luxeons.
    first hacked up my Antec TruBlue PSU, swapped the 92mm fan for a Noiseblocker model, cut up, shortened and resleeved ALL powercables, painted it blue, put on a plex-cap. Now looks like this.
    Luxeon time!
    Royal Blue, green, red-orange Lambertian models mounted behind the system fans, each thermal epoxied on an internal LianLi fangrill, that should keep the beast properly cooled!
  2. coorz
    coorz Miffed
    25 Apr 2003
    Amber, royal blue and green side emitters also thermal epoxied to some left-over heatsinks:
    Now for controlling these wicked leds:
    enter Q-Prox :clap:
    designed a transistor relay driver to go with the default Q-prox scheme and built these:
    So i hear you, how do you turn dem leds on? Well, the sensor has been connected to the metal of the outer fangrill, so a mere touch from the outside will turn it on. The side emitters have their sensors in a 'backplate'
    The 'PCI' card on which i built three Q-prox sensors also houses a serial IR circuit, it's a plexi case after all, so should be no prob to use it.
  3. coorz
    coorz Miffed
    25 Apr 2003
    Note on the Q-prox: default state is 'high' so made it a PNP transistor circuit. All those luxeons popping up when turning on the PC is quite a shock :eeek:
    My MO LCD also Q-prox'ed because being powered by the internal USB header meant it was always on :eyebrow:
    End result pix:
    more colour schemes and other pix can be found in my gallery;
    http://www.xs4all.nl/~rccheng/
    bwah fixed my pix, enjoy and comments welcome!
  4. kingkobra
    kingkobra What's a Dremel?
    18 Jan 2003
    That looks great! I love the color combinations.
  5. STellY
    STellY What's a Dremel?
    24 Aug 2003
    that looks extremely nice!!! good job.... can you post a pic of it finished in the light??? itll give us a better chance to see your wiring....
  6. Bossman
    Bossman What's a Dremel?
    6 Nov 2003
    I'm fed up of seeing bad ClearPCs, bad wiring, bad colour schemes, bad position of lighing. This however looks fantastic. Spot on! Exaclty what the ClearPC was made for IMO. :thumb:
  7. [t0rc]
    [t0rc] What's a Dremel?
    28 Nov 2003
    Superb!
    I agree with Bossman 100% on this one! Extremely well done!
  8. at_b
    at_b What's a Dremel?
    28 Mar 2003
    oh
    almost lost my eyes back there :hip:
    nice job :thumb:
  9. coorz
    coorz Miffed
    25 Apr 2003
    thx for the positive reactions,
    here's two daylight pix of the innerworks,
    to be honest, i'm not completely satisfied with the wiring. That rounded ATA cable is a major pain in the *ss, should go SATA in the near future.
    I'm looking for a plug solution for the fan/luxeon combo, kind of mini-DIN/XLR style plugs but very low profile. Very hard to find :miffed:
  10. Bossman
    6 Nov 2003
    Even so coorz, its far better that other feeble atempts at a ClearPC computer.
  11. at_b
    28 Mar 2003
    it sure is...
    btw...is the case slightly bent in the middle of the bottom plate? that s how it looks like in the last pic
  12. coorz
    coorz Miffed
    25 Apr 2003
    mmm, i notice it too now. But i'm sure it's not bent! trick of the camera lens probably.
  13. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    you mean for transparent reasons :hehe: ...I crack myself up :lol:
  14. coorz
    coorz Miffed
    25 Apr 2003
    Re: Re: Named it Plexeon
    ah! major correction time it is!
    obviously that should be 'apparent' , thx for spotting.
  15. Ronin
    Ronin What's a Dremel?
    26 Sep 2002
    Excellent
    :dremel: :dremel: I modded my PSU and changed the switch and also I painted it flat black i will post pics of mine after i am finish!
    But anyway great job!!!!! :thumb: :thumb:
  16. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Man, clear acrylic cases become more alluring eveyday. Love the clean execution shown by you and G-gnome :)
  17. coorz
    coorz Miffed
    25 Apr 2003
    thx, i believe that to make any clear acrylic PC, whether pre-mod or custom build, look good one has to dig very deep and sometimes go to extremes (Gnome's amazing ORAC), there's simply no place to hide.
    mnpctech, the things you do to PC's are also nothing short of spectaculair! :thumb:
  18. KRASH
    KRASH What's a Dremel?
    27 Oct 2003
    thats one of the best clear pc cases I have ever seen, Well Orac
    but then again g-nome has done some insane stuff to that beast!
    One of these days maybe I will try the clear case thing.
    :rock: :jawdrop:
  19. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    i love the lighting scheme that you have come up with.. looks very nice.. one of the few cases that are this style that I actually like... :clap:
  20. coorz
    coorz Miffed
    25 Apr 2003
    thx m8 :thumb:
    There seems to be a 'natural' aversion against these plexi cases. Making it look good is quite a task.
    Note: i omitted the optical drive, it will be 'externalized' together with a VFD and a BIG harddisk.
    I had prepared this slimline DVD-combo for the case, but decided against it.
    Now where shall i put this thing to good use, my ol' trusty Dell notebook me thinks. :naughty:
