Scratch Build – In Progress NANO-TV : a portable gaming PC in a vintage TV
Discussion in 'Project Logs' started by kim, 22 Apr 2018.
  1. kim
    kim hardware addict
    10 Jan 2016
    HI guys
    I love PC modding for so long, without having the balls to mod myself, but I finally started and I am happy to share my first mod, hope some of you would enjoy it
    It is the first of my 3 projects to mod my own hardware
    this one is a tribute to AMD (before Ryzen)
    ___________________________
    the hardware that I have already
    - FX 8370 4.3 ghz
    -Gigabite 970 gaming SLI
    -R9 Nano
    -Samsung 960EVO nvme SSD
    -Aerocool Strike-X PSU
    -water-cooling CPU :
    XSPC ION, XSPC 140mm radiator
    2 x 140mm Corsair fans
    water-block, fittings, tubes and accessories from various brands of Asia
    the hardware that I still miss as of now :grin:
    16 go (2x8) of ram ( HyperX fury red, or if I can afford, the new AMD gaming memory)
    3 SSD HyperX Savage
    may be a second R9 nano...
    THE CASE...
    The idea born last year after dismonting an old portable television from Radiola, I found the "shell" funny and I thought about building a PC inside.
    sorry for those crappy pics, I didn't mean to post it at that time, but unfortunately that's the only pics I have of the TV before modding it.
    The case wasn't deep enough for all the hardware, so I started by adding a few centimeters of plastic, heated, bended and glued
    and a fan grill from a vintage Pioneer car speaker
    the I used composite filler to unify the texture of the new shell
    many times I had to make the same operation because the composite filler becomes hard in a very short time, so I use small quantity of product
    I still have holes and scratches to fill, and a lot of work inside the case, but it starts to look like what I was aiming...
    I had a crack today, too many holes on this side I guess, I am actually fixing it and trying to strenghen this part of the case, but I have other holes to make here and there before final layers of composite filler
    on the top, I made some tiny holes for the screen knobs, because of course, I MUST put a screen inside of a TV shell :grin:
    I found a screen that fits the case not bad
    with a plastic window on the front, then I will have to mask the edges of the screen with black vinyl paper perhaps
    I used aluminium bars to hold the screen, using original holes made to hold the cathode tube, and sheets of alu to make a square case inside the curved one, more practicle to mount the hardware
    the electronic parts of the screen had to be moved on the right side to save some space on the left for the PSU
    but I cut a part of the controller shroud and used it to cover the electronic and kept the 4 spacers that I will use to hold the mother board tray, more or less like this
    The Aerocool Strike X PSU is great, it matches the colors of the case but it needs to be modified a bit, I started by moving the wires to the right
    because of it's placement, I have a very short space to route them
    also I think that there is a lack of light on the fan, so I added 4 red leds (better red effect when fan is on I hope)
    and a new paint, matching better the project
    I will use Bitfenix Alchemy cables, but I changed the color code
    the motherboard was a bit sad, all dressed in black, so I painted radiators in red, you can see a water-block from Freezemod, no idea yet if it's efficient or not as it is my first water-cooling, but if not, I will upgrade to XSPC raystorm (budget is my limitation, my only sponsor is me :grin:)
    you can also see one of the ram coolers, this is what I want to use for the ram, it comes from this kit of Adata 2000 mhz memory but the memory doesn't fit this mother-board, so I will only use the coolers
    well, that's all for now, I apologise for low quality of my pics, and my beginner skills, but I wish to become better and better with practise...
    thank you
    David, adidan and _Prometheus_ like this.
  2. Cheapskate
    13 May 2007
    Great start. :D
  3. adidan
    adidan Avatar now in stock for xmas 2019
    25 Mar 2009
  4. David
    David RIP Tel
    7 Apr 2009
    Oooh, interesting!
  5. Impatience
    Impatience Active Member
    6 Apr 2014
    Great concept!
  6. Vault-Tec
    30 Aug 2015
    This looks awesome. I'd love to do this to one of those 50s TVs. Watching :)
  7. kim
    kim hardware addict
    10 Jan 2016
    thanks a lot to all of you guys :grin: it means a lot to me if even great modders like my project...updates soon
  8. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Active Member
    14 Sep 2004
    Cant wait to see more loving this mod so far :thumb::thumb::thumb:
  9. kim
    kim hardware addict
    10 Jan 2016
    hi guys...I'm happy to start again the work on my NanoTV, almost a year from last post, but I really couldn't spare no time for modding since...
    Started by making a fan grill for the pump fan using the original grill of the TV (it can be seen of first pics of the TV), but my first try to stick a rounded grill failed with a crack, so I cut a square part of the grill and cut a square hole in the shell to stick it firmly, and the composite filler will fill the unwanted parts.
    more updates soon...
  10. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Good to see this project alive again kim :thumb: Cant wait to see more (again) :rock:
    Vault-Tec likes this.
  11. kim
    kim hardware addict
    10 Jan 2016
    Thank you very much DEFYaNt, it means a lot to me, I'm very excited to finish that project, and I have a few other ones "on the fire" to come...
  12. kim
    kim hardware addict
    10 Jan 2016
    after first layer of composite filler...got a lot more to do before it looks clean...
    In the meanwhile, I started to cut a hoop out of plastic :): don't know what sort of)...in a way to make a nice rim for the window on this side, cuz it's pretty ugly as of now, I'll make it in 4 parts and stick it together, because I don't have larger enough layers of this material ...wish I have an electric scroll saw too:grin:, but filling and sanding will do the job...
    to give you an idea of the final color and shape I am trying to reach, I show you what came out as the best option for my TV, of course here it's a radio, but the red color with the shiny rim is just so beautiful...
  13. Cheapskate
    13 May 2007
    :lol: I'll admit it. I forgot this was your project. I know you more for being one of those rare active members. Good to see it back. I also like that you are hinting at more projects to come.
  14. kim
    kim hardware addict
    10 Jan 2016
    thanks a lot Cheap...I'm definitely a slow modder :grin:, but I can't spend a day without coming here to watch projects, since 2010 I think...it took me some years before I had the balls to walk my first steps in the "big guys" courtyard :naughty:... but now I organised my life to save more time for modding, as it is really an amazingly artistic activity, a passion for me, who loves hardware and computers.
    I've got at least 5 projects, including the NanoTV. I've posted a summary of my projects in 2017, in the "modding" section, but my picture hosting site closed and it can't be seen anymore. My main project is a desk, I will talk about it after finishing this NanoTV:dremel:...thanks to all Bittech members for support and coments, it's a bigger reward, greater than any sponsor for me.
  15. Cheapskate
    13 May 2007
    Everyone of every skill set is welcome, just don't put a screwdriver in a live PSU.
    -Or paint hardwoods...
    -Or destroy an antique...
    OK, we do have a few things that set us off, but the PSU thing is for safety. :lol:
    kim likes this.
  16. kim
    kim hardware addict
    10 Jan 2016
    :grin: I promise you I won't commit any of these felony :nono:
    I spent afternoon filing and sanding that rim...still a lot to do but that's all for today...
    thanks for watching
    Vault-Tec and Dot_Kappa like this.
  17. Brett89
    Brett89 Active Member
    15 Dec 2005
    And I thought my project was retro, this looks awesome! Very nice touch with the grilles.
  18. kim
    kim hardware addict
    10 Jan 2016
    thank you Brett89...yeah :grin:, kinda "retro" but 70's design was so original, may be giving a new life to old vintage stuff is one of the new trend...see::winking:
  19. Vault-Tec
    30 Aug 2015
    Good to see you back on the tools, Kim.
  20. kim
    kim hardware addict
    10 Jan 2016
    TYVM Vault-tec...so happy to get back on it , this time, I won't side the tools 'till it's finished :grin:
