Hardware Nanoxia Deep Silence 2 Review
Discussion in 'Article Discussion' started by Meanmotion, 11 Apr 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Looks a bit like a Fractal case to me.
  3. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Even the top USB & power panel looks like it was taken from an R4 case.
  4. Hustler
    Hustler Minimodder
    8 Aug 2005
    Nice case design, less is more.
    Just a suggestion though, you guys really need to improve the lighting on your case photographs, it's incredibly harsh and doesn't do any of the cases you review any favours, almost impossible to judge the quality of the finish with the supplied shot's.
    Given that the first time many of us will see a case in the 'flesh' so to speak, is when we open the box on arrival at our homes, it's quite important, you show these cases in as much detail as possible, as we won't find any of these mid-high end cases for viewing, anywhere on the high street.
  5. Baz
    Baz I work for Corsair
    13 Jan 2005
    In all likelihood, they may share the same manufacturer in china, and as such, share some of the same tooling on bits like the front panel.
  6. Fractal Design
    Fractal Design What's a Dremel?
    30 Oct 2010
    We'd like to highlight that Nanoxia and Fractal Design cases doesn't share the same manufacturer, nor do we share any toolings. All Fractal Design cases are produced with toolings fully owned by ourselves.
  7. Altron
    Altron Minimodder
    12 Dec 2002
    More like clone. Aside from the two-part door, looks like they totally ripped off Fractal's design. If they had put the white PCI slot covers in, I would have sworn that the rear shots were of my R3. Same goes for the upper front edge, which would have fooled me if it wasn't for the USB 3.0 ports, and the drive bay area as well, if it wasn't for the third 5.25" bay.
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    And the brackets for the HDDs are absolutely identical (except for being black and not white)...
    The top front area also looks exactly like my R3 (USB3.0 ports and all) - except that I can't tell if the Deep Silence 2 has a blinding blue LED or not :D
  9. David
    7 Apr 2009
    ...and if it was for the fact that it's longer and narrower than the R4 and that it has room to support a 240 rad behind the drive bays...
    Yeah, if it wasn't for all that and the door, it'd be EXACTLY the same! :hehe: :lol:
  10. Xir
    Xir Modder
    26 Apr 2006
    I like the simplification of the buttons and ports on the top, and the omission of the air-chimney.
    What i don't like is the rigid bays and the ugly blowholes on top.
    They're not planning a MATX version are they?
  11. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    The finish on the panels looks horrible; a dull matte that shows up finger prints. The worst of both worlds.
  12. Joey Propane
    Joey Propane What's a Dremel?
    26 Feb 2011
    Mmmmm, steel and plastic...
Tags: Add Tags
