Storage NAS box recommendations please
Discussion in 'Hardware' started by okenobi, 22 Sep 2010.
  1. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    I'm running out of HDD space - again! Could somebody please tell me if it's possible to buy a box that will take some F3s and just plug it into gigabit and access it as if it were local? If so, how much?
    Otherwise, I may have to reconsider a new case and new machine etc.....
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Build a freenas box & use iscsi if you want them to look like they're local
    or map network drives to something like the netgear freenas
  3. okenobi
    3 Nov 2009
    You know I'm not as brainy as you, Sas! I don't care if they look local, as long as I can use them as such. A mapped network drive would be fine, but that's the limit of my expertise. I just want a box I can bang 2 or more drives in then use them for general data AND backup.
  4. wyx087
    15 Aug 2007
    Synology Ds410j is the one i've got, not a speed daemon, but relatively cheap for a 4-bay, and software is a delight to use, very flexible.
    problem is that most NAS will require you to re-format your drive on plugging in. so you may need to buy a couple drives with the NAS to get you started
  5. okenobi
    3 Nov 2009
    So realistically is £200+ for something reasonable, plus drives.
    For not much more I could just build a new machine and move all my HDDs across. Hmmm......
  6. saspro
    saspro IT monkey
    23 Apr 2009
    Or build a new machine & use your old one for freenas
  7. Parge
    16 Jul 2010
    Buy a second hand netbook, whack the HDs in an external enclosure, share the drives via USB. Bang.
  8. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
  9. okenobi
    3 Nov 2009
    All of the above suggestions involve spending a minimum £200 for me though.
    My current case will only hold 4HDDs, so really what I need is an R2 or similar where I can plug all 6 of my drives in and add more if I want.
    Starting to think along those lines. I didn't realise it had to be so expensive :(
    For just over £200 I could have the case and guts of the affordable all-rounder.....
  10. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Synology DS210j is an awesome bit of kit otherwise.
  11. wyx087
    15 Aug 2007
    i think the best way to do it is indeed build your own. that way, there's possibility of not having to buy spare drives by simply mounting existing ones untouched.
    of course, you'll need the time and patience to do it. i didn't, so went for a pre-built solution.
  12. okenobi
    3 Nov 2009
    Yeah, looked at that from the previous poster. Cheapest I can find from somebody I'd buy from is £170 and it only takes two drives.
    I think the sheer volume of data I'm dealing with is the problem. Joe Schmo just doesn't have 3 or 4TBs of stuff that's important to him. For most people a couple of 1TBs in RAID would be lovely.
  13. Baz
    Baz I work for Corsair
    13 Jan 2005
    Hope I'm not ruining or upcoming bit of content, but the DS210J is very, very good for the money
  14. kenco_uk
    28 Nov 2003
    2 x 2TB drives?
  15. Glider
    Glider /dev/null
    2 Aug 2005
    I have a Synology DS410, not the cheapest of kit, but it is good value for the money
  16. Phalanx
    28 Apr 2010
    You're not Baz. I think most people have seen how well Synology make their kit :)
  17. okenobi
    3 Nov 2009
    Does anybody make a reasonably quick, well priced 2TB unit?
    My last 5 drives have all been Samsung either F1s or T series....
  18. DaveMon
    DaveMon The end is nigh! Repent!
    21 Jun 2010
  19. okenobi
    3 Nov 2009
    I wouldn't use anything green and 5400 is too slow. Looking on Scan, everything 7200 with a 5yr warranty is well over £100 :(
  20. dukebox_1st
    dukebox_1st What's a Dremel?
    26 Apr 2002
    I have the Netgear Readynas duo and am quite happy with it. It has gigabyte connectivity and takes two drives. I use 2x 1tb Western Digital Green drives.
    It's currently £140 on ebuyer with a free 500gb drive. Sell the 500gb drive, £25-30 i'd imagine and then bung two larger drives in it.
