Storage NAS box recommendations please
Discussion in 'Hardware' started by okenobi, 22 Sep 2010.
  1. wyx087
    15 Aug 2007
    haven't CPC already done a feature on NAS? that's why i chose Synology for my NAS (but 4 bay version as 2 bay is not enough)
  2. Parge
    16 Jul 2010
    Hey Bit Techers, what do we think of things like this
    - Basically a way to share external USB HD over the network
    - Would be great for me, not even having to reformat! - if they work......
  3. saspro
    saspro IT monkey
    23 Apr 2009
    It's going to be slow.
    I'm not overly sure you'd be able to plug & go either.
  4. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Thanks for all the help guys. I'm gonna need to do some pricing up and comparing stuff before I take any action....
  5. kenco_uk
    28 Nov 2003
    I have a 2 bay Zyxel NAS-220 and it's brilliant apart from the fact that transfers to it are not as quick as I'd hoped. Even in raid-0, it seems to be hitting a wall somewhere as the best I've got is around about 12MB/s, despite the unit and my rig having gigabit connections and using cat6 or cat5e. It's the same with XP, Vista and 7. I was expecting around 70MB/s but it's got to be the NAS's shortfall tbh.
    If I were to set up a m-itx, is there a good read/write throughput, i.e. with two drives I'd expect 70MB/s or more? The trouble is, I'd want to expand on more than two disks too although 2.5" disks would be fine if space is limited, as they're now available in the 1TB size.
  6. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    To add a bit of logic to the mix... If you're talking about building a NAS box, connected over network (even 1Gbps), the network is going to be the bottleneck, not the 5400RPM spindle speed of the drive. If you were going to consider a NAS, why would you NOT consider new drives despite the spindle speed?
  7. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    Did your test use DSM 3? I just realized that they snuck out that and some Android apps when I wasn't looking.
  8. wyx087
    15 Aug 2007
    DSM 3 is still in Beta phase....... best to wait for official release. unless the NAS is something you don't mind loosing.
    there could be so many limiting factors, i think usually the RAID controllers will be the limitor even with 5400rpm drives and gigabit LAN.
  9. klutch4891
    4 Feb 2008
    I could be wrong but from what I can see it's not in beta for the 209, which is what I have. It looks like the officially supported firmware as of 9/21. DSM3.0-1337.
    It's not a huge performance difference from what I've seen so far, it just lets you multitask through the web interface.
