NAS recomendations
Discussion in 'Hardware' started by kempez, 6 Apr 2008.
  1. kempez
    kempez modding again!
    4 Aug 2005
    I want a NAS for home so am looking at them now.
    I wouldn't mind RAID 1 and need above 259gb storage, preferably with room for up to a terabyte
    I have Vista 64bit too :)
    I've seen this:
    NETGEAR SC101T
    But I've heard bad things about Vista 64 support
    Anyone know anything about NAS?
    BTW: Deffo has to be a networked drive, I want several PC's to access it over the network
  2. Glider
    Glider /dev/null
    2 Aug 2005
    How about a homebrew, low wattage server? It offers way more flexibility than any NAS can give.
  3. kempez
    4 Aug 2005
    I just want a networked drive with RAID 1 for backup purposes, can't be bothered to faff about building another new PC, just want a nice small package that I can plug in, install drivers and away I go.
    It's not really in the home builder spirit that I usually do stuff, but meh :)
  4. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    The Buffalo DriveStation Duo 1TB NAS box is 'just' £160 from Amazon.
    The Buffalo 1TB LinkStation Pro Duo NAS is £196.32 from IT247.
    Or the Thecus YES Box N2100SM 7-in-1 NAS Server is £210 from Scan, but (according to Scan) it only accepts "up to "800GB"?
    Whether any of 'em support Vista 64 or not though, I can't say?
  5. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I love my lacie especially now that the update has added upnp server functionality so i'm all happily streaming to my PS3. Sadly there RAID solution doesn't have this functionality. And yes.. they are available in the uk.
  6. Guest-16
    Guest-16 Guest
    The Thecus N2100 is great :thumb: I got a £75 one from Evesham :D
  7. kempez
    4 Aug 2005
    The buffalo or the lacie BigDisk look good.
    I spose the Thecus is off of offer now Bindi ;)
    Thanks for the tips guys :)
  8. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  9. kempez
    4 Aug 2005
    Hmm I'm torn between the cheap and 1tb pre-installed Buffalo or the nice looking Thecus that is very expensive and has no drives.
    I think the Buffalo may win out
  10. Hazardous
    21 Jan 2004
    I'm inclined to agree.
    £50 is quite a premium to pay [for looks], when the £160 Buffalo DriveStation Duo has everything you need otherwise :idea:
  11. shadow12
    shadow12 I lie
    30 Sep 2007
    Personally I like Thecus but out of the ones you have shown I think the Buffalo will do.
  12. kempez
    4 Aug 2005
    What makes you say you like the Thecus? Is it purely looks or is there some technical reasons? Just wondering if there's much difference...
  13. shadow12
    shadow12 I lie
    30 Sep 2007
    I have not seen any reviews or had personal experience, so its completely based on looks.
  14. kempez
    4 Aug 2005
    It does look good, I vill give ya that :D
  15. gingerprince
    gingerprince What's a Dremel?
    10 Apr 2008
    You do realise that that's not actually a NAS unit, it's just a USB/Firewire drive...hence the cheap price.
  16. Anobis
    Anobis What's a Dremel?
    28 Mar 2006
  17. kempez
    4 Aug 2005
    I realised, so it was OK :)
  18. h_2_o
    h_2_o What's a Dremel?
    24 Jun 2004
    I have a qnap and absolutely love that thing. stable, quiet and works amazingly well. anyway that is my .02 cents
