i know what half of you are going to say- but i did! here, at molex, at mouser, everywhere!!! i even found the part i need on jameco's site, but their part number didn't match anything at molex... anyways, i need to know the part number for the male r/a (or vertical) floppy disk drive power connector. i think the pitch would be .1" or something very close to that. anyone know it?
The ATX spec is an AMP connector, not Molex, which might explain your problem. The female end (on the psu side) is AMP 171822-4, may get you started. It's a 2.5mm pitch. http://www.linux-1u.net/PowerSupp/Conn/
Pitch is at .1" Jameco's Part Numbers for what you want 4-pin housing: 114930CC Female crimp for 114930CC: 114921CC 4-pin M rt. angle PCB mtg: 114999CC
See http://www.dpninc.com/pdf/man6639d.pdf , section 4.1.2. It is a great manual with more info about floppies than you will ever need. I wish all manufacturers were that thorough. (If that link ever goes dead google for "YD-702D-6639D" )
thanks everyone. wow, i feel totally inept. i spent at least one solid hour looking for this stupid thing! whew!
Added to the list. Long-term plan is to make Useful Links menu-driven & add links to more Useful Posts, to help find stuff easier & without burning out your scroll finger.
