Graphics Need a new GFX card! But which one... ?
Discussion in 'Hardware' started by tsutton, 8 Nov 2020.
  1. tsutton
    tsutton Minimodder
    29 Aug 2003
    Hey all,
    Been a while since I upgraded my system so I am out of touch...
    I am increasingly frustrated that I am not able to play the latest games and when I am able to find a game that works, I had to lower the quality of the game so I can play it. Plus many of them requires DirectX 12.
    And my video card is pretty stone age - it's a ATI Radeon HD 4800 - 512MB
    Yeah, I'll wait when you have finished laughing. ;)
    Here is my current spec:
    ASUS P8Z77-M Pro
    Intel i5-3570K 4 Cores - 1150 socket
    3.40Ghz
    16GB RAM
    Windows 10 Pro (Build 2004)
    I am looking for a new GFX card, I'm happy with 4GB vRAM but bonus if it's 6GB. And my budget is about £130, but can go a bit more if it's well recommended.
    I was thinking of the GTX 1650 but pretty much of them are out of stock...
    Important note to add
    I have dual monitor setup (2 x HP 24w) and will require to continue using this. Both monitors can do HDMI or VGA. Bonus if I can go full HDMI as I currently use VGA -> DVI adapters
    Thanks all and keep safe!
  2. Vault-Tec
    30 Aug 2015
  3. tsutton
    tsutton Minimodder
    29 Aug 2003
    Thanks for that. Is there a HDMI -> DisplayPort adapter that ACTUALLY works? I've got two here that doesn't do anything, think it could be a cheapo eBay China crap. :grin:
  4. Vault-Tec
    30 Aug 2015
  5. tsutton
    tsutton Minimodder
    29 Aug 2003
    Oohh, how about the RX580 as it has 2 x HDMI ports and 8GB, means less mess in the rear side of my PC with adapters and I can find one for £147.
  6. Vault-Tec
    30 Aug 2015
    Yeah better card too. I would expect 1080p VRAM levels to hit 6gb within the next year or two as well.
  7. tsutton
    tsutton Minimodder
    29 Aug 2003
    Yup, futureproofing it at the same time. When you think about it, I had the ATI Radeon HD 4800 for over 10 years so hopefully will be the same for this one too. ;)
    Have ordered it.
    Thanks for your help/advice.
    Vault-Tec likes this.
  8. adidan
    25 Mar 2009
    I had a Sapphire RX580 Nitro for a short while, quite capable cards TBH, even coped with some older games at 1440p.
  9. SuperHans123
    SuperHans123 Minimodder
    27 Dec 2013
    I've just recently bought an Asus Strix RX 570 8GB card for £145 and it performs really well, even at 1440p. Currently playing Star Wars Squadrons with all settings maxed at about 70fps and that's with a crappy Pentium G6400.
