Need a PCI-E SLI PSU
Discussion in 'Hardware' started by cfuk, 24 Mar 2005.
  1. cfuk
    cfuk What's a Dremel?
    9 Jul 2004
    I'm after a new psu to power my new SLI set up. I've got a Tagan at the minute and just had to buy two PCI-E cables that take the power from 4 pin molex plugs. I have seen a Tagan 2Force psu on scan, but they said that they have had them on order from the last two weeks. Is there a psu out there that has two PCI-E 6 pin plugs?
    Also if i use the 6 pin for 4 pin cables do i need to run power to both plugs? is when you look they both have cables leading to the 6 pin plug.
  2. Kensei
    Kensei What's a Dremel?
    26 Sep 2004
  3. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Well, Bit just had one, don't think they actually performance tested it, but there's a short review of it on the front page. Seems good to me...
  4. cfuk
    9 Jul 2004
    well i've put an order in a tekheads for the psu :)
