Windows Need a Rainmeter Skin made :)
Discussion in 'Software' started by mat0tam, 5 Jan 2012.
  1. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Hi All,
    So Ive discovered rainmeter and it is amazing. At the moment though my desk top software part looks like this:
    I Manage to merge 2 part of a rainmeter skin to include HDD stats in system however I really want to take all the values that everest measures and display in my skin.
    Basiclly - Everest readings into Rainmeter Skin
    Is that possible?
    If you manage to help me you WIN A MYSTERY PRIZE :) - Il send you a gift
  2. Krikkit
    21 Jan 2003
    I'm not sure I quite follow what you want - those two info boxes merged?
  3. mat0tam
    1 Sep 2011
    Yeah pretty much, My knowledge of rainmeter is sketchy and I was hoping I could make it take the readings from Everest and display them in the skin I have already got.
    "Cleared up my first post too :)"
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    You can do it with everest, but it's messy. I recommend using openhardware monitor instead. There is a good working rainmeter plugin already and skins values are a lot more straight forward. See here.
  5. mat0tam
    1 Sep 2011
    Thankyou :) I will look into this then hopefully report back with a success :)
